Alternator cooling fan
Guys check your fans my fan hub bearing went out I ordered a new hub bearing So today in prep for reinstalling everything I bead blasted the fan itself 😳
Here’s the crack so to me it’s a fan looking for a place to fly apart 😢
Yikes
That’s a bit hard to not notice if it wasn’t covered in paint…. Great Catch!
I know it may seem a bit off-putting for some, but spray your belts with Dressing and the fine particles will find themselves clinging to the MAG and protect it. Yeah, it will look a bit 60/70’s Le Man 24hr racer, but it’s protected. I know a few that mist (very lightly and finely) a spray bottle with lightweight motor oil to have the fan induce and coat everywhere.
P.S. The alternator will be fine.
In this picture it is labeled not my picture but from another Rennlister Superdylan I believe cost like 6 dollars online. A bunch of cars that use Bosch alternators use it
You got me thinking so I went back and looked at every picture I could find of the fan that I have and couldn’t see anything
The more I think about it I’m not so sure the crack isn’t new when I first took it out I took the shroud off first and was spinning the fan and you could clearly see a wobble in it so maybe a combo thing bad bearing 30 year old fan bearing starts to go fan cracks maybe Cobalt will chime in he knows his magnesium castings
Got it. That’s pretty interesting that the paint was laid in such a way to cover that crack without a impression of sorts showing.
Fatigue instead of the actual casting based upon what you say “wobbling.” The Mag takes a lot of heat on the cool down and thermally expands a lot.
