Hi All
Does anyone know the measurements for the C4 drive shaft CV boot or have one that they could measure for me?
Small opening internal diameter?
Large opening internal diameter?
Length?
Width?
I'm looking for an alternative to the OEM rubber boot, was thinking something more versatile like polyurethane...
As I seem to require new boots every 2 years or so due to cracking or actual splits, just got flagged on my service as an advisory to watch.
Small end inside dia = approx 15/16 in or 24mm
Outside dia= approx 1.25 I. Or 32 mm
large end inside dia 2 1/8 approx 55mm
Outside dia = 2 13/16 70 mm
3 3/4 in length or 85 mm
There is a lip inside of large end that protrudes
aprox 1/8 in or 4 mm
Thanks John, you're a star, that's much appreciated
Great info, forgot about the sealing lip on the large end
Would be interested George in what you find works (and where from in the UK). Have the same C4 problem - anything that avoids a really messy repeating job!
I would also be interested in what you find George, particularly if they are made of polyurethane. I will have a brand new set of the cheap ones arriving here in a week or two from Pelican, and I can confirm dimensions if needed. For an installation that is as tough as this, it would be nice if the boots lasted more than just a few years.
Just realized that not all CV boots are the same size on a C4...
Part numbers and pics below, I'm guessing from the pictures that the dimensions we have are for 92833229302
So can anyone help with the dimensions for 96434929100
Never gave it a thought the one I measured are for my MY91 C2
No worries, thanks for confirming
Just found a spares site that lists multiple brands of CV boots with the dimensions, a bit of variation in the measurements so I listed the min-max.
Unfortunately all appeared to be made of rubber, so the hunt continues
