Do Cup 1 Wheels fit 89 964 C4?
Hi all, I’m going to apologise in advance as I’m sure this question would have been asked before! I have just procured an 89 964 c4. I am wondering if cup 1 wheels with the following part numbers would fit without spacers... in layman’s terms? 😅 thanks!
965.362.124.00
965.362.128.00
965.362.124.00
965.362.128.00
965.362.124.00
965.362.128.00
965.362.124.00
965.362.128.00
Good luck !!
Rocket Rob (03-16-2021)
Ok so this is in the Porsche TSB bulletin # 49106
and the part this is pertaining to:
Porsche Steering Fork Spacer Genuine Porsche 964-347-325-02 96434732502 964.347.325.02 964 347 325 02 | Pelican Parts
The placement is well pictured it this diagram below as # 6 (the price is better too)
1989-1994 Porsche 911 Washer 964-347-325-02 | Sunset Porsche Parts
The 65mm offset wheels are also 7.5" instead of 7". They will fit with a 10mm and look nice with a 15mm spacer BUT you wanted a spacer free application. Also you'd need to change the wheel studs for longer.
The short answer is yes they do, but careful with a full turn lock as they will rub a little on the inner liner / fender up front without the spacer in the tie rod ends. (Not a wheel spacer, but a disc that limits the turning radius and stops rubbing (steering angle spacer) - not absolutely needed as I have been driving without it for more than a decade now.)
Good luck !!
Good luck !!
these are part numbers
96536212401
96536212601
well I wouldn’t have minded having spacers but in Australia, I can’t get the car road worthied with non factory wheels and spacers. It’s a pain!
