964 Forum 1989-1994
gasoline "leak"??
Old Mar 26, 2004 | 11:24 PM
JoeW's Avatar
JoeW
Default gasoline "leak"??
While I was out "practicing" in a parking lot today for the up-coming autoX season, I found once again that a hard turn to the right with a full tank of gas results in overflow, leakage, whatever. Enough so that it smelled and the area around the top of the filler pipe was wet.
One other 'Lister has said it happens to him, too.
1. Does it happen to your car?
2. Have you found a way to fix it? Joe W.
Old Mar 27, 2004 | 12:18 AM
Eric Kessel's Avatar
Eric Kessel
Joe,
First check the gas cap. The seal ring can be replaced. Also, the cap can lose it's "force" that causes the click when it's fully closed, so it clicks before it's fully sealed........ And, you might take a look at the filler neck, since it can become out of round. Porsche has updated that part about 6 times. There is a procedure for replacing it on John Miles web site.
I replaced my cap, and filler neck piece in an attempt to cure an occasional gas smell in the car/trunk during warm weather, and this didn't help. Now that it is warming up again, the smell is back......not everyday....... so, next i'm going to replace the 14 year old rubber hoses.......
-Eric
(Oh to answer your question, I never get fuel out the cap when driving "aggressively")
Old Mar 27, 2004 | 03:46 AM
Bill Wagner's Avatar
Bill Wagner
Joe:
Check the archives....this has been covered many times, and the archives include diagrams as well as some step-by-step instructions.
If you've got gas coming out of the top, it's more than likely the filler neck needing replacement as well as the gas cap gasket (it's old now). If you want to do it to minimize the cash, try replacing the gas cap gasket first, then if it still leaks replace the filler cap. My car did the exact same thing as yours, and the leaking didn't stop until I replaced the filler neck too. I then had to pull the carpet out of the car and wash it thoroughly to get rid of the gas smell.
Many others have done this and it's stopped the leaks out of the top, but for some reason the smell of gas continues. I suspect it's some type of venting issue, but that's just a guess.
By the way, replacing the filler neck is not a difficult job. It took me about an hour to do.
Hope this helps,
Old Mar 27, 2004 | 09:45 AM
dsanto's Avatar
dsanto
Had the same problem on my 91 turbo and replaced the filler neck. Not sure if it fixed the problem but the old filler neck was corroding at the bottom and need replacing none the less. Curioius thing is that unless I replaced the neck I would have never know about the corrision and it would have eventually clogged the fuel filter.
Dennis
Old Mar 27, 2004 | 10:45 AM
JoeW's Avatar
JoeW
Thanks to all, and thanks, Bill, for encouraging me to continue my search. My first tries hadn't come up with what I wanted, but following your name gave me my next job for the day, what I'll now call the "Bill Wagner fuel filler leak test":
Here's a simple test to tell if you have the bad filler pipe:
1. Fill the car up with gas.
2. Before exiting the gas station, completely dry out the area around the gas cap.
3. Find an area of road where you can safely do some fairly high speed left and right turns and then be able to get out of the car quickly (a BIG EMPTY parking lot will do).
4. Drive your car and execute some high speed left and right turns.
5. After executing the turns, QUICKLY stop the car and then pop open the fuel filler top.
If there gas lying in the area of the gas cap, you have the fuel filler problem, and the fuel filler and cap (or at least gasket for the cap) need to be replaced.
I used the test above to verify that I had this problem. After replacing the cap and the filler tube the problem is gone. The gas odor didn't go away until I took the carpet out and gave it a bath.
And utimately, if the gasket fix or fuel filler replacement doesn't do the trick I'll have to follow Adrian's suggestion in the same thread to charefully check out the expansion tank.
I'll let you know if I find anything unexpected. Thanks, Joe W.
