Passenger side front window
Cruisin'
Hi all, I have an issue with front side passenger window and appreciate any assistance. The driver's side window switch went bad and it blew fuse # 4 (window regulator). I replace the fuse, I replaced the bad switch with the passenger door side switch temporarily until a new switch comes in. Now only the passenger side window works. The passenger side window does not respond to the switch commands. Anyone have an idea what the issue could be? Any help would be greatly appreciated.
I have the same issue. Only my drivers window is open by about 4 inches and I can't get it back up. Is there any way of winding the window up for the short term or at least til I can figure out what the problem is..? The older models had an emergency crank handle I think.
I've changed switches around with known new ones, checked fuses etc so I assume I'm into a new motor for the window and that sounds rather spendy I think.
Any advice gratefully received..
Cheers
Mark
Cheers
Mark
Cheers
Mark
Cheers
Mark
