Heel and toe pedal set
Originally posted by DavidI
I've seen pics on a web site (a few months ago) of a block of wood strapped to the accelerator pedal....
It's by far the most cost-effective improvement of my car
Details are on this page.
It makes the Fat Foot method a lot easier.
Cheers,
JW
As you can see, I have the brake pedal adjusted to be in one plane with the throttle. Since this caused the above mentioned problem with the brake lights, my mechanic welded a longer screw to the pedal (if I remember correctly).
Futhermore I have a wodden block under the throttle pedal and with the Sparco pedals it is easy to adjust the position of the pedals relative to each other.
Heeling and toeing became second nature after those mods!
http://hobbystage.net/porsche/media....9444426-003713
Julian
Here are the pedals that I constructed myself. I also use the "fat foot" method so depending on how you atach them you can get vary the distance between left side gas pedal and right side brake. I have calculated that distance to be around 2.0 cm minimum. Brake pedal is curved and a bit longer so you dont need to lift your heel from the floor
Chances are that that was on my site
Cheers,
Originally posted by burgass
And here is how they look
hmmm...ahem.... This is a picture of MY car (1995 cabrio)... and no these are NOT the AJUSA pedals....
These are VOSSTEK race padals...
Burgass or DJF1,
What steering Wheel is that? It has an air bag?
PS. I believe rennsport is selling those pedals for much less
I am not sure but it looks lake Raid:
http://www.raid-rdi.com
Chech the steering wheels. By the way they sell same pedals which are exatcly the same as Ruf but a lot cheeper
Cheers
Cheers
Originally posted by cobalt
Burgass or DJF1,
Burgass or DJF1,
Now if you asked me where I bought it , I got it directly from TechArt when I was in Europe and its not cheap...but for me worth every penny.
Hope that helps
JW - That's the one! Bookmarked now as one day I'll get around to the sports wheel upgrade with extender too!
Cheers,
JW
