964 Forum 1989-1994
ABS relay questions
Old Oct 29, 2020 | 11:35 AM
Otto Bonn's Avatar
Otto Bonn
Default ABS relay questions
my my abs relay is on the fritz. I pulled it out. I don't see any obvious failure, which pins activate the relay?
Otto Bonn's Avatar
Otto Bonn
Should be positive 31 and ground 15 correct?
Old Oct 29, 2020 | 12:07 PM
P356GT's Avatar
P356GT
30 Line from battery positive terminal
31 Return wire from battery Negative or ground (direct)
15 Switched positive after battery (ignition-switch output)
87 Input
this is Bosch own designation of numbers
Old Oct 29, 2020 | 12:16 PM
Otto Bonn's Avatar
Otto Bonn
I thought it looks like 31 and 15 go through the coil windings on the diagram.
Old Oct 29, 2020 | 12:26 PM
Otto Bonn's Avatar
Otto Bonn
so if so positive on 15 and negative on 31 should activate the relay?
Old Oct 29, 2020 | 12:33 PM
P356GT's Avatar
P356GT
So when you turn ignition on the relay will be activated and pull and give power to 87 that are given signal /12Volt to xxx
Like the #30 + gets connected to #87 to deliver +
Old Nov 8, 2020 | 05:07 PM
Otto Bonn's Avatar
Otto Bonn
how do these connections look?
