I purchased a seeley pressure bleeder so I can bleed the brakes. Followed the instructions and built the pressure up to 10psi all of a sudden theres a large gurgling sound and brake fluid is vented via an outlet tube behind the front righthand wheel well. Thought it was a damaged brake line at first but there is a vent tube there. So re tried the process and same thing happened again. If I do the standard bleeding system using a person operating the brakes its fine. So us a brake bleeding pressure tool not suitable for a 964?
This https://rennlist.com/forums/964-foru...procedure.html is invaluable. First picture shows the clamp off. If it makes you feel any better I've forgotten the clamp a couple of times and seen the puddle of doom.
