Best AC guys in Chicagoland
Any have recommendations for the best AC guys in the Chicagoland area?
My 964 seems weak blowing air and temp readings on hot days only register about 10 to 15 below ambient temperatures.
Not sure if I should send my CCU (climate control unit) to the folks in Florida that claim they can upgrade units to perform much better ... for 1k plus!
https://www.ecudoctors.com/products/...47-00-upgraded
Anyone have experience with rebuilding CCU?
A couple of thoughts. It is most likely not your CCU. Tore is the authority on all things CCU. You'll find plenty of answers on this site. Have you had the refrigerant changed from the old R12? The lines most likely did not get changed so you may just need a recharge. If you are looking for a great independant shop in the Chicago area, try Perfect Power.
Like most of us you probably have a leak in your system somewhere. Search for some other recent threads on this topic.
