Turn key no power no lights all dead
Hi guys need your help Please...turn key and no power no lights no sound everything is dead.
check battery changed overnight all good checking the battery, same thing turn key no power no lights no sound nothing.
Thank you for your help!
Are you sure the battery's good? Because what you describe certainly sounds like a dead battery (or something silly and electrical like a disconnected negative terminal).
I just had a one year-old Interstate battery die on me. I have thrown it on a charger over night about once every week to try to maintain it, but it still won't hold a charge. I put a multimeter on it, and it "charges" at 11.8 volts, with a resting voltage (off the charger) at 11.4 - 11.6 volts.
Is it so dead that not even the dashbord clock works? Try with another battery!
How old is the battery? How many years do you expect a battery to last?
everyone who reads this and knows that they have a battery more than five years old, buy a new battery or the old one will let you down when you least expect it!
Thank all for suggestions it could be the battery it hold charge at 12.8 v.
interesting I unhooked the battery charge it and hook it up again after playing with the key on the ignition few times I back and forth it made contact and I could started.
Check all your ground connections, start with the one from the battery to chassis. Take it right off and clean the surfaces at battery and chassis.
