Heat Duct Block Off and Fan Block Off
My car is outfitted w the FVD exhaust w no heat. Wouldn't it make sense then to just delete my fan blower and add the heat duct block and fan block off parts? Not even bother w the RS bypass tube?... Is there any other reason to keep the fan blower in there even though it currently is operating just fine at least I think..
https://www.fabspeed.com/porsche-964...off-1989-1994/
I believe the engine bay fan provides additional engine cooling in certain circumstances, doesn't it? Also, the air temp sensor may be an input the CCU needs, even without heat?
The rear fan has two purposes, (1) push heated air to the cabin and (2) cool the engine. If you have no exhaust heat exchangers you could remove the fan.
However, the Climate Control Unit will shut down the two front blowers if the fan does not operate. To avoid this you have to keep the temp setting at minimum. I guess you already do.
Cheers,
Tore
Cheers,
Tore
Cheers,
Tore
Cheers,
Tore
I removed the fan and added a relay to the rear fuel box and my car does not run any warmed and my heater fans in the front work on all speeds. the fan in the rear is just for the heater If you look at the piping you will see their is no way It cools the engine. May be just the heat ex changers.
Wallra—I’m thinking of removing the rear fan on my car, but still want heat in the cabin. Do you have instructions and photos of what you did? I understand rear fan removal has no affect on a/c, right?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
