964 Forum 1989-1994
Strut brace choice
Old 03-02-2004, 12:15 PM
John52
John52's Avatar
Default Strut brace choice
I plan to purchase a strut brace for my 92 coupe. However, I do not want to cut or remove the carpet in the trunk. Looking at pictures from various manufacturers there seems to be a variety of approaches regarding the design of the end plates that attach to the strut towers.
Can someone share there experiences regarding braces that install without carpet cutting or removal.
Old 03-02-2004, 12:32 PM
cobalt
cobalt's Avatar
Received 2,223 Likes on 1,327 Posts
I just went through the same thing.
Most designs require cutting the carpeting. Which design achieves the maximum stability I cannot tell you. I have tried three different bars with rather varying designs. I found no discernable difference between them. They all appeared to improve the stiffness. Although some weigh more than others.
I settled with the factory bar (which cost almost double) because it allowed me to cover the bar with the carpet instead of cutting it. The carpet is somewhat lifted but in place. It may be cheaper to buy a second carpet and modify it using an aftermarket brace then it is to buy the factory bar.
Good Luck
Old 03-02-2004, 01:36 PM
joey bagadonuts
joey bagadonuts's Avatar
Here's another option from Racing Dynamics.
Old 03-02-2004, 02:17 PM
Ruairidh
Super Guru
Ruairidh's Avatar
I like that Racing Dynamics design. I have the AJUSA and while no cutting was required it does need the carpet to be bent back a tad - but not so I notice or care.
Old 03-02-2004, 04:02 PM
Bill Gregory
Technical Specialist
Lifetime Member
Bill Gregory's Avatar
I got the Brey-Krause bar, which can be seen at http://www.bkauto.com/porsche/r1530.php
Old 03-02-2004, 04:44 PM
PC2
PC2's Avatar
The Brey-Krause carbon fiber brace look great.
Old 03-02-2004, 04:49 PM
Michael Delaney
Michael Delaney's Avatar
I just put a Weltmeister strut bar on my Speedster. I was able to put the carpet back over the bar. However, now I can't see it. I'm considering cutting the carpet so I can view my new addition when I open the lid.
Old 03-02-2004, 05:35 PM
ian c - u.k
Registered User
ian c - u.k's Avatar
porsche sell a replacement carpet for use with strut braces
Old 03-02-2004, 05:43 PM
ian c - u.k
Registered User
for cars with velcro fastening
964 551 067 1
for cars with velcro fastening and cd changer
3.6 turbo parts
Old 10-06-2005, 11:52 AM
puma1824
puma1824's Avatar
So what is everyone's preferred choice over a year later?
Old 10-06-2005, 09:01 PM
pete000
pete000's Avatar
I like my Racing Dynamics bar. I picked up an extra carpet set on ebay and cut slots in that. Then I ended up running a Cup Car RS light weight carpet.
Old 10-06-2005, 09:11 PM
Turbohead
Turbohead's Avatar
I have an extra front trunk carpet . You could cut if need and still retain the original.
email me if interested in it
Elliot
Old 10-06-2005, 09:34 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
I like my Rennline brace - I got mine in black and installed it under the carpet so no cutting was required.
Marc
p.s. Photo is from Rennline web site (www.rennline.com, no affiliation).
Old 10-06-2005, 10:16 PM
hjcarlin72
hjcarlin72's Avatar
I like my Fabspeed srut brace. Carpet goes right over it with no problem.
Old 10-06-2005, 11:48 PM
puma1824
puma1824's Avatar
For those of you with adjustable ones...how hard to adjust? Would I need to take to my local specialist to adjust?
Quick Reply: Strut brace choice
