Drivability comparison 964 TS vs 964 3.8 RS
I know the specs but I’m really interested if these two monsters went head to head on street and track will for lack of a better term a road and track comparison pros and cons.
I can't say for sure but very different animals.
First off are you talking the 92 3.3L TSL or the 94 TS flachbau/package car. IMO there is not much difference between the 94 TS and the stock 94 turbo. Slightly More Hp with a different turbo which is a bit slower at spooling up. Some simple bolt on mods to a stock 94 turbo will make it a better performer.
The 3.8RS/RS uses the turbo brakes with turbo front suspension setup. The rear uses a variation of the narrow body trailing arms vs the big heavy turbo rear trailing arms. IMO this is the best setup. Wide Body with narrow body rear suspension. The 300+ hp of the 3.8RS is nice but the torque of the turbo and power delivery is quite different than the N/A engines. 0-60 is probably not much different but the turbo will pull away rapidly after that. The Turbos are heavy with a lot of options more of a street monster vs the 3.8RS which I assume is more track focused. Lighter weight and spartan.
Both great rides for the day but very different rides. I really enjoy my turbo although the suspension setup on my 3.8RS tribute is much better. My 3.8Tribute fails to be a comparison since it is essentially everything 3.8RS with a 993 n/a twin turbo low boost engine and short geared 6 speed box. So it will decimate either on the track.
BLACK3.2 (12-16-2019)
As Cobalt says, it needs to be clarified if you’re speaking of the TSL (Turbo S Leichtbau) or the 3.6 Turbo S. The latter is such a completely different type of car (heavy, fitted with every luxury option and really more of an amped-up GT) that there is no way to compare it to the 3.8.
The TSL and 3.8 are similar in feel on the road - both very light and nimble. Small (especially when compared to anything modern) and really usable. Of course, the TSL has a lot of lag, it’s an old-school single turbo. Feels to me like a Porsche go-kart. The 3.8 is a bit more planted and less twitchy; and being NA, the power band is more balanced and smoother.
They’re each dramatic in their own way and evoke their era wonderfully.
BLACK3.2 (12-17-2019)
Speaking of 3.8RS... just gorgeous
![](https://lh3.googleusercontent.com/sb0r1gHKMgqBvTq-CjT4UNF4srxfobqPgSHRK7QVd7WOapmkjHQ10lwk40FrAMNuCxyPt-wRAomevqnkW3DbyTSGT7lJAEzm7X5lBANU97fOy4W0NHBP8CLVxnhFSP-NLIIbLbNuB87wQZ9YCNve1vEP32xlvdgCB6Nsku93cNRXB8XFapbnANgIFTReoOu2EIRQuXrMlC2XdcOpzVnTjm8lHchnybeNZghooK9LFSK7SMLaC8tr_HG1rTN_5-GoAXMwFB8G5VWY8iMeYzU96_1fQSj6-YRzL9XardVe_xgxet7Dgs3_cTdCFsb93xhB5I-yVkTznxQFNKkM4Yz4qyXv_reIh4cHsohK49sW9jxLvqbea94rr6Wm4vNXYIh1BkgTuuDNyJIirzIxZrPQMYDfzODsLK-c4q5lCm87_Y1zYjSPzt6NZinawy2AU9zLdBDy7wHwe-KD9yB6RSReyJ9B0W5hk1xOyRLoaN_L5SZP7qcNNh7vLO_jO5aPhzMKH1iC-rOwW-x-N5EqTd0I7BTQiwCE-5F7Hd883pBjWDzpO-TG-uIz-4ygx4yVZEOhwExOBvxH4OtwIMebB68pEn89VdcKLAmJegFxzlmMU5yEjFxbj5LW8g-WGX1s6CxfTyGS0XlZmdck3W8qlTH5hKahzXTNxcQCP2ernVq7kXo9ICwTUTeu__GEuWeoR47q2fmZ24323sYInxNI8A5lDW6OqjjGbU4d0I4TqQIUM54W24pl=w1680-h841-no)
![](https://lh3.googleusercontent.com/vgQQ-uQxzXvHm9O7L5OD7d9BddrVx0OxGEMYE2mVIDkMgoRFnsSu9IKCzEt4LnuonJXqw0ZoWgPTghwMpA2sf96MyOnBjvMZgTksbTrIjulve_HQWoiXnHE_QVb-nStmOzJ-WWdBlIIOF5jGeBNxB-fac_IRpRcOY_W0xhUP22jn0DifajZ239C-Ihi2RJ8cM0O_INFeov27YnB63TYXfjMP1iaHx63NfaZrRWIE3N2cUw9165BgAVxcWBo9idKAv4CDf0YFzwjoJd5YPUee7QMEjbCVHE-IUwlrgDnHHa-uAK3gX_016BLz28Y6o1F-C5vrm-05ZKSmvCGuF9q5lToZfw7Z_qB_7vzFwBe-ChXij9RqkQjZ-I44rZPq0ye0iKO1OJFNbC6Kw4jmER-3dBHRKKi1Vsg9CovS0Pyv3cJeri1DjDZx1bzJKa63J-oXU_x9cVPb1yKnmZC2forn90_bnzhXyIzUJHdSPp_WlRt-fPAb4pUzq3DZTWnU9MjomogLgpSbkbgYYHt8GaRxBGazbYePdJ_PHHR_U-9gXWgpyDJi23q5ant3uhFC7NumwDPMgg1UKHg0MzQVfplx1kh87VlJ8e2DwQ5qwejYW1BCgnUUdolDiTlWXPPKwpCDTKBDtjV4a5qT6_wyGQpTxki94ukeB8LTtsLv2YWgVk2he-kdU_Y9zIpFdgoHthvABT0tIOJLd0eQj5sMz8V8HkwYibPfvyvvCufrc4RP1i1H9Evn=w1581-h935-no)
911Jetta (12-17-2019)
Yep. But the car has been sitting a one of the local Porsche dealerships for the past month. (Porsche Southpoint)
Pretty lucky to just be able to walk off the street and see this!
Dealer Facebook picture:
![](https://scontent-iad3-1.xx.fbcdn.net/v/t1.0-9/72143302_10157668011804413_5264361781442117632_o.jpg?_nc_cat=108&_nc_ohc=1zN5PdjjqTwAQmYe4dwWANFUKa1I20rYygt7ULq-QlllarIpJ4KfXuvhQ&_nc_ht=scontent-iad3-1.xx&oh=9c7d5b6806978b6c22eaa308678cb8a1&oe=5E6A7E30)
