Frunk Gasket Question
nip that bud...
dunno there, lookin a little deeper than i would be comfortable with just cleaning it up, she's been bitten(?) pretty good...
I am seeing a lot of this lately and even more surprisingly seeing a lot more 993's with this and rear window issues that the 964 doesn't have as much of. I would at a min treat it well with a rust inhibitor and try to fix any leaks until it is time to cut out and repair.
At least the 964's don't see it this badly by the rear windows. That is all being cut out and replaced. My friend is doing these on a regular basis now. It appears as the 993 is aging it isn't faring as well as the 964's which usually had a rougher life.
I guess it all depends on how it was stored and cared for. More 964's were allowed to sit outside than 964's as they were the neglected stepchild for so long. My friend has several 993's in his shop now having these issues addressed. He does this on 964's as well although the 993 seems to be surpassing the number of 964's he sees with this issue. It would appear as these all become over 20 years old the design flaws are showing up.
With detailing product evolution you can get away from using large amounts of water entirely if you trust the following approach to remove dust, bugs and light dirt.
- Start with a California Duster and gently wipe it over all the car surfaces except tires and wheels.
- Spray one panel at a time using a high quality quick detail spray like Griots Speed Shine or Pinnacle Crystal Mist
- Wipe the wet panel with a high quality microfiber like Cobra 530 in a 16 x 24” Size or the Griots grey PFM towel
- Start at the top and work your way down but avoid the rockers and wheel well areas until the very end, once the entire car is clean go back to the rockers and clean them and then the wheel well area.
- Use a separate lower quality microfiber for the wheels and never mix towels, each should be dedicated to a specific task. You can use the same approach for the wheels.
I’ve done this for all my fun cars for the past 15 years and I can promise that if you buy the right products, don’t use microfibers if they drop on the floor, wash Microfibers correctly you can maintain a swirl free paint for years without the need to polish or wash with water.
Water wash can be limited to very heavy surface dirt like after a major rain storm or long drives in the rain. Here is a pic of my Spyder which has been water washed twice in 8.5 years and 18k miles. I did a very light polish about 5 years ago and the paint still looks flawless
Afshin,
Didn't anyone tell you it is rude to put your butt in our face. LOL That spyder is stunning.
Sorry
I've been down this route, water getting in Frunk and Cabin.
My bonnet seal was split in all four corners so thought that was the issue.
Had it replaced but didn't resolve my problem
So had the fenders removed just encase there were bigger rust issues unseen as no signs of rust on the surface!
Once removed it revealed a lot of surface rust under both fenders, but no holes
All treated, fenders and bonnet seal re-installed.
Water still getting in Frunk and Cabin
Turns out I had two issues!
Water in the Frunk now appeared to be due to a poor fitting bonnet seal, by poor fitting, I mean the seal was a pattern part from an indie and not the original article from Porsche.
The cheap seal when compressed by the bonnet lid, caused the seal to stick out past the edge of the bonnet, which when it rains, would mean water can get past the seal...
Don't cheap out on this seal, get it direct from Porsche
The new seal from Porsche fits a lot better but still isn't 100% so I'm investigating further and have an imminent carbon bonnet install that I hope will resolve the issue as it needs to be made to fit.
Water in the cabin was mainly caused by split door velvet strips and old door seals, not from the HVAC area in the Frunk as originally thought...
With the velvet strips replaced, it has pretty much sorted water getting into the cabin, just replacing the door seals now as the old ones were very squished and had lost there springy softness, should be monsoon proof then
Good luck.
dukmon (01-16-2020)
Took a grinder yesterday to get down to good metal, cleaned things up then fabricated some aluminum to cover up any holes caused by the rust. Epoxied in place. Putting the new PORSCHE gasket in later today.
But I’d definitely recommend getting the fenders removed to check out how bad it is underneath...
Mine only cost £500 which is about $650.
