"Holes" in the engine compartment
Next to the motor mounts close to the bumper, there are two "holes." One is plugged and one is open. I assume that the one that is open shouldn't be. I've looked thru the E_964_KATALOG-2.pdf, which is an exercise in patience, and haven't been able to find this part. Can someone out there tell me what it's called (in Porsche katalog speak) and a part number?
thanks in advance
thanks in advance
You do want the plugs to prevent additional heat from the exhaust getting into the engine compartment and to the motor mounts.
