964 Harness mounts
Looking for some photos and part numbers that i can follow to install harnesses into a 964. I have both the BK water jet cut plate style harness bar and the BK tubular harness bar. But i'm not sure how to anchor the actual harnesses to the car. My seats are 996 gt3 seats with manual 996 sliders and the BK adapter kit. Thanks.
you can see my build list thread, in signature.
rear to welded in bar
center lower to cross bar bolted to seats with reinforced chassis mounts
side mounts to chassis on tunnel with backing plate and to OEM seat belt point on outer
thanks that was fast. i am trying to be less invasive with the car, and maybe that's not the safest/best route, but figure it's better than a street set up. Any alternatives to a welded in bar and drilling the floor?
You could:
Use a cross brace / mount under the seats
Use the side OEM mounts with the seat belts
You'll need a harness bar or bolt in bar for the shoulder harnesses
