964 Forum 1989-1994
Stuck hex bolt
Old Aug 30, 2019 | 04:25 PM
cjoenck's Avatar
cjoenck
Default Stuck hex bolt
So this am I was hoping to change the final drive oil for my '90 Tip. Theoretically easy, right? Remove fill plug, remove drain plug, etc. except I can not get the fill plug to budge. Soaked in PB blaster, etc. but am working with a somewhat stripped Allen bolt. I am wondering if I could use heat but the fill plug is very close to the axle. So what now? I don't want to get metal shavings into the final drive but this bugging me. The bolt is pretty rusted and looks like it hasn't moved in ages. Any good ideas?
Old Aug 30, 2019 | 07:17 PM
Goughary's Avatar
Goughary
Get a new plug for when you reassemble.
If you get stuck and start looking at last resorts, get a sacrificial allen socket- 1/2 drive. Clean the nut on the trans very well, and then epoxy the allen into the plug. Let that set over night, crack loose in the morning. Throw it away.
Someone else may have a much better suggestion - but that would be my last resort.
Old Aug 30, 2019 | 09:10 PM
JohnK964's Avatar
JohnK964
I don’t remember how much room under there but maybe possible to use an impact driver you know the kind you hit with a hammer to loosen it
This kind
Old Aug 30, 2019 | 11:16 PM
cjoenck's Avatar
cjoenck
I tried an impact wrench and that helped round the plug. I have drenched it with PB blaster overnight and hope that helps.
Sacrificing an allen key may not help because the bolt is already rounded. How much torque can epoxy glue hold? I think my impact wrench delivers about 500 lb ft. I am losing the plug for sure, I already ordered a new one.
Old Aug 30, 2019 | 11:43 PM
Deserion's Avatar
Deserion
What about screw extractors? Worked a charm to pull a stripped bolt from my expansion valve. Shouldn't get any shavings into the trans either.
Old Aug 31, 2019 | 12:19 AM
carlskisWP's Avatar
carlskisWP
Yep, screw extractor is what i used to break loose a stripped hex bolt from the rear caliper. One thing though I had to cut the tip off the extractor to get it to bite good in the rounded out hex hole
I did not have to drill the hole out. After that it broke loose pretty easily.
Old Aug 31, 2019 | 05:54 AM
newsboy's Avatar
newsboy
How bad is the stripped Allen bolt. Dipping the Allen wrench in oil, then into fine sand takes up the slack. Has worked for me, worth a try.
Old Aug 31, 2019 | 06:56 PM
cjoenck's Avatar
cjoenck
I hadn't heard that trick before. At this point I have nothing to lose and will try this. Have been soaking it in PB Blaster for a day and will try again tomorrow.
Old Aug 31, 2019 | 06:57 PM
cjoenck's Avatar
cjoenck
I can't find any metric extractors so I will try to find a standard that fits a 10 mm rounded hex if all else fails.
