964 Forum 1989-1994
C4 FDM Short shift kit?
Old 05-21-2019, 08:49 PM
Greg Wolfe
Greg Wolfe's Avatar
Originally Posted by velocitylover
Do you mind sharing the price?
How about a possible Group buy?
Not sure if they have exact pricing published anywhere, but I will say to use your existing shifter and boot, you will be slightly north of $300. There are other add-ons such as the Billet shifter, Delrin Shift ****, and Swine11 Re-boot for an additional charge. I decided to get it all. All in, about double the base kit.
I am told this is an introductory price and it will go up on the next run.
I don't think the pricing is a secret, but in case it is, please don't quote my post in case I need to remove the cost.
Mr. Wolfe
Old 05-24-2019, 02:15 AM
Poli84
Poli84's Avatar
Myself and @andy73 have got the Sleepers SSK on pre-order too, ours are being shipped to Australia so may take a while to arrive but can't wait.
Old 10-31-2019, 04:13 PM
Greg Wolfe
Greg Wolfe's Avatar
Just curious, has anyone installed their Sleepers kit yet? I received mine months ago, but haven't installed it yet. Would love to hear about how it feels and how installation was.
I ended up buying a new boot as my stock was not in great shape. I think I am also going to have the rod powder coated flat black and I may grind a notch around the shifter for the top of the boot to nestle into. It is a VERY tight fit as the shifter is much thicker than the top of the boot.
Mr. Wolfe
Old 10-31-2019, 09:15 PM
spartansix
spartansix's Avatar
I reached out to Sleepers about buying a kit, but never heard back. Do you think it would be possible to use a different **** with their setup?
Old 11-01-2019, 09:26 AM
Greg Wolfe
Greg Wolfe's Avatar
I would imagine. I don't know the thread size, but I am sure someone does.
Mr. Wolfe
Old 11-01-2019, 10:05 AM
2swoosh
2swoosh's Avatar
I would love to have this on my C4, thank you fellows
Old 11-01-2019, 11:19 AM
911 jared
911 jared's Avatar
Mr. Wolfe
Yes you can use an after market shift **** which is real nice. Thread pitch is 10x1.5.
Old 11-01-2019, 11:25 AM
samurai_k
samurai_k's Avatar
One of the advantages with the FDM AWD SSK is that you don't need to "dimple" the tunnel cover. They updated the design of the shifter to make it shorter than the 2WD version to make it fit in the tunnel. I actually have both in hand right now. Will share a pic later to show what I am talking about. Also the comment about the golden rod... Yes you should get it to complement the ssk as it replaces the rubber bushing joint with a solid one making the shifts more direct. As a consequence there is more nvh felt in the shifter which is a nice
Old 11-01-2019, 11:27 AM
911Jetta
911Jetta's Avatar
Big Goldenrod fan here! Every 964 deserves one.
Old 11-01-2019, 11:37 AM
onelove
Basic Sponsor
onelove's Avatar
Mr. Wolfe
Take the Rubber shift bellow and flip it inside out, cut about 50-60% of the big rubber block portion off. You can then use a bit of water based lubricant and lubricate the opening in the shift bellow, reach from underneath and spread and pull down and over the shifter and it will fit. We've used this method to get the bellow to slide over the integrated shift **** on the Rothsport shift **** with great success so it should work perfect for the Sleepers version where you can remove the ****.
Instagram :Swine11 | TitanMotorsports
Swine11 ReBoot - 964 / 993 Shift Boot Trim Panel
2004 996 GT3 | 1986 Carrera 3.2 (future Keen Project) | 2016 Cayenne Diesel
911Jetta (11-01-2019)
Old 11-01-2019, 11:45 AM
Greg Wolfe
Greg Wolfe's Avatar
Thanks for the info guys. So I can add the Golden Rod to my kit on my C4? Does it replace anything from the Sleepers kit or just add to it?
Mr. Wolfe
Old 11-01-2019, 12:02 PM
911 jared
911 jared's Avatar
Mr. Wolfe
im almost positive FD motorsports doesnt have a golden rod for 964 c4. Only for c2 964 and 993 c2/c4.
Old 11-01-2019, 12:05 PM
911 jared
911 jared's Avatar
Thats awesome that you dont need to dimple the tunnel cover. But is that just for 993’s? Or does that include 964 c4’s as well.
Old 11-01-2019, 12:53 PM
samurai_k
samurai_k's Avatar
Learned something new today. Looks like the GR does not work for the 964 C4. It's does on the 993 C4. Curious why?
Old 11-01-2019, 01:47 PM
samurai_k
samurai_k's Avatar
Here are pics of the 2WD shifter vs AWD shifter by FDM. The 2WD version is longer and thus requires you to dimple the tunnel cover if you wanted to use the 2WD shifter in a AWD car. The updated Awd version is shorter so no need for the tunnel cover modification. Besides the shifter itself the forward rod is different too. Longer for the 2WD version and bolts on the subframe whereas the AWD version snaps on the torque tube.
I had started the 2WD conversion on my AWD car, and changed course back to keeping the car AWD. Contemplated using the 2WD SSK that I had already bought with the AWD system, but didn't want to deal with the headache of building a custom forward rod and dimpling the tunnel cover that I ended up buying the AWD version instead after consulting with Darin at FDM about my options.
Quick Reply: C4 FDM Short shift kit?
