Idle problem
The idle on my 93 RSA oscillates at about 1Hz and on occasion the engine will stop completely when I take my foot off the gas at a light. Performance when I'm on the throttle at all is fine.
Any suggestions on what this could be? Airflow sensor? Idle valve? Can anyone suggest how to troubleshoot this?
Thanks,
Bill
Thanks,
Bill
Professor of Pending Projects
Also, replace the DME relay... cheap and most times the culprit... (at least it was in my case)
I also read here that oil overfill can cause this - oil contamination in the air flow sensor...
