120,000 KM sevice
Valve adjustment, spark plugs, air/fuel/oil filter, oil, brake fluid.Brake check/cleaning, belt check from your ignition distrubutor, fan blet check. My be check my 100000 miles service fron 11-'03 and see for your self.
Thanks Arjan !! The previous owner had the 120,000 KM service done, however it does not specify what was actually done on my receipt (says 120,000 km recommended service completed). I know the fuel filter was not changed nor valves adjusted. The case through bolt O-rings were replaced, L & R cam housings resealed (Left side is now leaking again), O-ring on intermediate shaft cover replaced, new clutch assembly, clutch flex hose, transmission input seal and DMF of course, airbag service done, brake flush and rear spoiler deflector replaced all at the same time as the 120K service. It also got a new alternator 1 month later. The previous owner spent over $8000 in this 2 month period. Very Scary !! That is the main reason I bought the car, he had all the ugly, expensive stuff done (I guess it's all expensive when it comes to Porsche's) PCNA is going to warrant the now leaking again Leftside cam housing, even know it was the previous owner who paid to have the work done. Nice to see them step up to the plate. Oh, the joys of owning an oil cooled Porsche !! Sometimes makes you want to drink. Regards, Brady
