LW Flywheel will stock clutch work?
I just baught a new Light Flywheel off of ebay. I am wondering if my stock clutch disc and pressure plate will work. The reason that I am so curious is that I installed a new clutch about 6 months ago. The clutch was for the dual mass. Also I would like to know if the stock starter ring can be removed and re-installed on the light FW.
Any comments will be greatly appreciated.
Duncan
Duncan
The pressure plate used for the single mass and dual mass flywheel is the same. The driven disc is different however since the dual mass unit has no torsional springs, so you will need a new driven disc 964.116.011.30. The RS ring gear 964.114.143.01 is different as well, also you will need to change your throw out bearing to 944.116.080.00 and the throw out bearing guide tube to 950.116.813.06 on the transmission.
LW Flywheel reply from duncan
Cupcar,
Thanks for the tip I'll look into a new disc,release bearing and guide.
Ive seen them advertised at Importech.
Thanks again,
Duncan
Thanks again,
Duncan
