Best headers / exhaust combination
#31
quick resurrection of what I am assured is a dead post.
1. how is it that the stock 964 set up is so good when the vast HP gains seen in the 993 cars had to do with a less restrictive exhaust set up? just curious
2. also above someone asked who does the singer exhaust set up, anyone know ?
w/o valve overlap tuned headers only provide better mass flow
a 964 oe exhaust has 3.75mm primary tubes flowing into 64.9x33.5mm x over, flowing into 2 mufflers and a cat
the most restrictive part is the primary muffler(396cfm@6500)followed by the cat(442cfm@6500) and then secondary muffler(462cfm@6500)
at 100% VE a 964 flows 413cfm@6500
surprize, surprize the factory put an adequate flowing exhaust on the cars
now if you change the cams to something w/ a little bite, say SS cams then the headers can add something to the party.
cobalt (09-20-2023)
#32
993 picked up 22 hp and 14lb-ft from combination of exhaust head/valve and air flow measurement changes
I know we haven’t Met but you’re a true knowledge master on this forum and appreciate the follow up. You don’t happen to know what the 3.8 L RS 993 flow looks like as it pertains to exhaust size?
#33
Currently running a cat delete with secondary bypass, it's definitley the most rewarding sound on a 964 IMHO. Im sure there's small gains to be had but as Bill mentioned, not much without head/cam work.
#34
993 street exhaust is 39mm(1.53") ID primary tubes, Cup and RSR ran 42mm(1.625") ID primaries but also ran to 7400 rpm, where low is 503cfm
PAOLOP (09-17-2023)
#36
Pete
#37
On this side of the pond in Switzerland two specialists with rolling roads recommended independently of each other the standard headers, sport cats and a primary cup by pass.
(Mecacomponents & Sportec)
#38
