964 Forum 1989-1994
OEM Cup 1 Wheels with Spacers?
Old 03-13-2019, 12:28 PM
Goughary
Goughary's Avatar
My msi lugs are black.
Old 03-14-2019, 12:20 PM
weekndr.porsche
weekndr.porsche's Avatar
Just placed my order with MSI.
They do offer a standard black coated lug, it's just not listed on their site.
Went with the 74mm stud for the rear, and the 58mm stud for the front.
They are currently on a 3 week lead time.
I'll post details and pictures once I get my setup complete.
Old 03-15-2019, 10:22 AM
galanevans
galanevans's Avatar
I think the stance with your 5MM spacers looks pretty great...full but not overdone. What spring setup are you running in this picture?
Old 03-15-2019, 10:40 AM
weekndr.porsche
Here is a contrasting, rear view of the car.
The wheels are still pretty tucked in.
Photo credit @lowxjosh on instagram.
I am on Bilstein PSS10 coilovers
Old 03-15-2019, 10:47 AM
tonymission
tonymission's Avatar
This is with ET 55 and 5mm spacers all the way around?
Old 03-15-2019, 10:57 AM
weekndr.porsche
Exactly correct.
Old 03-15-2019, 11:17 AM
-nick
-nick's Avatar
Those fronts tuck in quite a bit too. My 7.5" have an effective offset of et48 (et52 & 5mm spacer), 225/45/17 tire and around -1.6 camber at RS height. That pushes them out about 9mm more than your 7" et55 & 5mm spacer. I've considered pushing them another 2-3mm. Here's my favorite offset calculator to make easy comparisons- https://www.willtheyfit.com
The feel is essentially imperceptible, but spacers do reduce the effective spring rate slightly due to the longer lever arm. The increased track width seems to have few downsides, though I haven't thought about how it might effect roll center geometry and such. Certainly less dramatic than the factory wide body no matter what.
Old 03-15-2019, 05:27 PM
galanevans
galanevans's Avatar
Ok - I'm confused by these calcs. I thought the spacer & wheel offset combination was just straight math...a et55 wheel and a 8mm spacer would get you a 47mm offset. Right?
Old 03-15-2019, 07:12 PM
-nick
-nick's Avatar
^ Yes! My front offset is 52-5mm, weekendr’s is 55-5mm. But my extra 1/2” of width makes mine stick out another 1/4” (6mm) on each side compared to a 7” wheel.
Old 03-16-2019, 12:04 PM
Porsche917K
Porsche917K's Avatar
17x8 ET52 Front
17x9 ET55 Rear W/ 15MM Spacer
Old 03-17-2019, 12:38 AM
weekndr.porsche
Originally Posted by Porsche917K
17x8 ET52 Front
Looks good!
I'll have to share this photo with my buddy, that is his Black Turbo next to yours. Ha
Old 03-17-2019, 07:24 AM
Navaros911
Navaros911's Avatar
You running standard sized studs with that? What's the limit again... 6-7mm?
I recall 7mm for the rear. That's what I'm running. Works fine on WB with Cup1 OE as well as the MM Cup replicas. This setup is not aggressive though and visually it would work better if they were pushed out more.
Old 03-17-2019, 07:44 PM
urquattro20Vt
urquattro20Vt's Avatar
Looks good!
Cool pic - Our cars look great! Foggy morning at Rennsport....
Hid how dirty my car really was.
Brandon
'91 911 Turbo
Old 03-18-2019, 11:37 AM
tonymission
17x8 ET52 Front
That looks amazing! Any rub with the 8s on the front? I bought a set of 6 Cup 1 wheels. 7s, 8s and 9s... Thinking to go with the 8s (ET 55) on the front now and 3mm spacers after seeing this picture.
Did you have to do anything else besides adding longer studs for the rears?
Old 03-18-2019, 01:46 PM
911Jetta
911Jetta's Avatar
That looks amazing! Any rub with the 8s on the front? I bought a set of 6 Cup 1 wheels. 7s, 8s and 9s... Thinking to go with the 8s (ET 55) on the front now and 3mm spacers after seeing this picture...
My car has 235s on 8s up front, and 275s on 9.5s (with a 5 mm spacers) on back. No rubbing from normal steering, but does ocassionally scrap on bumpy back roads during spirited driving =;>
Definitely a "plump" looking set up. My previous car has 7.5 (205) and 9 (255).
Quick Reply: OEM Cup 1 Wheels with Spacers?
