Hi.
During engine rebuilding problem has occured with too loose valve guide.
Even when using oversize one it still goes loose.
Part number is 964.104.321.50.
Do you have some idea what is the best solution?
Are there bigger than standard factory sizes?
Is there some good source for it?
Thank you.
One of the guys may have an answer for you here, but try posting your question over in the Pelican Parts 911 Engine Building Forum also (http://forums.pelicanparts.com/911-e...uilding-forum/) that one is pretty specialized on engine build details and the posters include some very experienced builders.
