My question with autoflex is 1) How much overspray is there, and how hard is it to remove and 2) what do autoflexed cars look like after you peel the autoflex off?
I've been turned off of doing a vinyl colorchange wrap by the fact that even the good ($4000+) wraps require hours and hours of removal time and come with no guarantee that they won't damage your paint.
Thanks for the input guys. I know I probably will have to sell everything and just wait for the right opportunity. I can't help but think that someone has one of these squirreled away that they don't drive because they look silly in it haha
Thanks, the car is currently on 18" Rufs and the Cups are ion the shelf!
Well, if you decide to part with the Speedlines, let me know.
That autoflex is interesting, but I think I would be too afraid to do something like that. I know a slew of people who can wrap, but yes you are in the 4-5k range to do it right.
That Autoflex looks interesting. I’m also debating a temporary color change on my Polar and that may be the way to go.
I think it is the best route for temporary color changes.
I will try to answer your questions, but I am no expert, just been researching the stuff a lot. 1) Unlike plasti dip, with Autoflex, you mask everything aside from emblems, fender reflectors, etc. You can still just peel it off those while the paint is fresh. You mask everything else just like painting a car. If you have overspray, it's the masker's fault. 2) The paint should be 100% the exact same way. There are a bunch of videos on it if you take a look on youtube. You need to build up the layers of paint. For instance, you use 10 layers of paint. 6 of the layers are used as a base or primer layer and 4 of the actual color. You would start with 2 gallon of clear paint and add tints (let's say gray for your 6 base coats) and then would tint the other in what ever color you want. You then only spray 2 coats of clear. One tack coat and one wet coat. After that you can sand, buff etc.
I think most horror stories you hear are because this is a DIY project, though they say the Autoflex should only be done by a pro. I have painted car panels, trunks, etc. in the past so I am definitely DIYing it. BUT, anytime you have a large project that is a DIY, people will short cut the process, get bad results, and then blast the product. I am sure you know this.
Regardless, I am going to do the color change in the spring. In the meantime, over the next few months, I will be ordering colors and tints to make the exact color I want. I will be shooting random objects for practice and also just to see how it peels, etc. Hope this helped some.
There is a set of the Rufs on BaT currently! ��
Yes, wrapping you are in the $4-5k range with is pretty expensive IMO. I could probably do it myself for a 1/3 of that, but every thread or review of someone taking it on either has bad results, or they want to kill themselves by the end. To have a professional shoot your car in Autoflex, I think it is around $2k ($500 DIY).
If you search autoflex on youtube, you will find a horror story of a Nissan Z. From my researching, I think that was just a badly done job all together. That painter should not be using Autoflex or probably any other paint.
Regardless, watch out for my journal in the coming months if you guys are interested in getting my real opinions.
OMG Maritime and Marine Blue interior, this is pretty much the pinnacle of the 964 world, low Miles, C2, manual. All the money but with this car you are only very (very) early, not wrong.
Plus you can raise at least 90k from your car and the 2 M5s........at least.
Thats the car I mentioned above, was told it was already sold (staying in NC) or would have let you know earlier. Lot of money (think only the hood has been resprayed) otherwise a top 1% car.
The interior blue is super, super dark blue and is very close to black. Its in perfect condition and looks fantastic. Matritime looks very flat and light blue under the showroom lights, but pops outside.
If you're that open to modding, wouldn't it be even cheaper to find a domestic redwhiteblack manual C2 and then respray it to the color of your choice?
I tend to agree, if a more permanent modification is acceptable I would just have your current car wrapped and call it good. It's a known entity and a dark shade of blue will look great with that red interior!
