Here are the current pics of the car with the red calipers, new tires, wheel wells cleaned. Going to Drivers Choice on December 5th for tie rod install, 4 wheel alignment with corner balance, axle fix and oil leak diagnosis. then, going to the paint shop for bumper refresh , then the detailer is coming over to wash, decon, and stage 1 paint correction.
Also, that is one cool contraption... I am going to make one for my car when I do not want to bother with the lift...
EDIT
Originally Posted by Ljuice10
yes, Harbor Freight. They were on sale last week, 20% off for the jack and special lifting tool for the front. There is a few spots in the front you can get the part under the car safely.
Ha! Not worth the effort to make them... going to HF with a 20% discount coupon to get a set..
Took the car to Drivers Choice for the following:
-Ride height adjustment from full stance mode to very aggressive street
-@elephantracing bumpsteer kit installation
-Full alignment and sway bar/end link adjustments
-Rear axle rebuild due to boot failures
-Resolving some typical oil leaks with new timing cover gasket set, a new front crankshaft seal, including a full oil service.
Reason: Pics
