Trying to work out an alternative to the Porsch (expensive) oil fan resistor. I checked Bergvillfx site and he suggests a resistor value of 0,45Ohm og 52,5W, Just wondered if anyone had used any of the following two, and if they are the correct type. Any advise appreciated.
Arcol HS100 Series Aluminium Housed Axial Wire Wound Panel Mount Resistor, 500mΩ ±5% 100W
Ohmite 850 Series Anodized Aluminium, Metal Axial, Solder Wire Wound Panel Mount Resistor, 100kΩ ±1% 50W
