For a starter...
I am not alone!
http://forums.pelicanparts.com/porsche-911-technical-forum/575942-flywheel-clutch-kit.html
I guess the issue is the starter gear which according to a post: " The setup i've seen is a bit odd in that it uses two ring gears (one to engage the starter and the other 964 part is used as a spacer), "
looking at pictures on autozones site you have to have an 1989 starter https://www.autozonepro.com/results/...requestid=6706
Anyhow let's recap for future kids that will look into this forum for that obsolete vehicle that actually requires the driver to drive that their granpa left them and are unaware of how it operates .
This is my starter from my 1992 964.
The problem is that when mounted on my other G50 box, which has a 87-89 housing, the shafts hangs out free like my xxxx under the shower. You can see on the far left in the picture below.
The correct starter for this bell housing is this one below, which obviously is too short for the 964 clutch and flywheel pack - but it works fine on the 3.2's.
Notice the end structure to hold the shaft in place.
So, yeah, need to find a way to hold that shaft up on my old, original 92 starter..
T
The shaft of the new one is too short.
Curious: People have mentioned tapping on the starter motor to get it working again...
Which part of the starter do you tap on when you have starter issues. The bigger black cylinder or the smaller one?
Edit: Thanks for the answer Rob!
VVVVVVVVVVVVVVVVVVVV
https://californiamotorsports.net/pages/contact-us
I will give them a call later today...
Strange that you had the same issue since yours is a G64...
