Tool for removing rear shock mounts
Gotcha.
You are looking for a socket that has an opening through which you can hold the top of the strut. They are available. Otherwise you can use a "through socket"
I think this is what you are looking for. I can't remember the size - 17mm?
But as has been mentioned. If you just hit that nut with an impact gun it'll come right off without spinning the shaft.
Just be careful w the springs. Lower the height adjustment on the strut to as low as possible to relieve as much spring tension as you can.
Originally Posted by jskylarwilson
Originally Posted by Goughary
Gotcha.
Attachment 1290832
Attachment 1290832
Originally Posted by ffc
I think they can be called oxygen sensor sockets. There are variations in type. I just checked my old rear suspension and the top nut is 17mm.
Originally Posted by johnsopa
Didn't know a tool like this existed. Good find!
Sorry, I got carried away. The sockets I showed are good for front suspension, holding the top nut with an allen key fitting of some kind.
