Tool for removing rear shock mounts
Hello,
Can someone help me find the tool for removing the rear shock mounts? I have pass-thru sockets for removing the fronts, but the rears have this stud that's flat on the sides and rounded on the ends. I've tried to remove these on previous cars with vice grips, and end up damaging the stud. I can vice-grip the shock tube, but I'd rather keep everything in good shape.
Here's a picture for reference.
Thank you!
Thank you!
Am I wrong or is it a 90 or earlier car ?
Originally Posted by JohnK964
Soak it in penatrating oil.
Why not remove from the car before you try breaking that nut loose. That is how I did mine
Penetrating oil would probably help, but how do I grip the funky stud (flat on sides, rounded on ends) properly, so that I don't destroy it? I don't know what tool would hold that piece in place, and that's what I'm trying to figure out.
I haven’t seen the top of my rear shocks for quite some time so I went and peaked and I do believe you are correct Thank You👍
Originally Posted by Ralph3.
Looks like a later mount to me.
Here is a pic of mine apart. I suggest you soak the nut, yours is a bit rusty. Nothing special about the nut and holder. I used a high quality adjustable spanner (you can just see it) to hold the flat flange while I turned the nut. It is not that high torque. It is much better system than the front and the silly 7mm hex.
My new suspension hasn't arrived yet - I'm preparing so that I'm ready with the proper tools when the suspension gets here. I will most definitely take the whole shock out of the car before trying to remove the nut.
There are three small 13 mm nuts on the top mount for the assembly. Take the bolt at the bottom of the strut assembly out of the trailing arm. Then remove the three 13mm nuts. The entire strut assembly comes out.
Then, if you don't have the proper and safe tools to compress the springs, take the assembly to a shop to have them take the top hat off if that is what you need to do.
I don't have a good safe spring compressor tool, so this is what i do. It's the way i stay alive. Don't mess with springs under pressure unless you know exactly what you are doing. Any shop will charge you 20 dollars to take them apart. So it's not worth the risk.
I say this, cuz it seems from what you posted, that you want to take the center nut off while the strut assembly is in the car. And this is the wrong way. If I'm missing something, lemme know.
Originally Posted by GoatFarmer
I have simply used an impact gun for other cars. The key is to relive the tension with suicide sticks so the springs don't go flying.
I say this cuz it seems from what you posted that you want to take the center but off while the strut assembly is in the car. And this is the wrong way. If I'm missing something, lemme know.
The assembly will come off the car before I try to dismantle. The picture was while the shock was in the car because I haven't taken it out yet. That seemed to confuse a lot of people.
The question was looking for the tool/bit to hold the stud so that I can hold it when I'm ready to do the work, so I can reuse the shock mounts. I found one, so I should be good to go. Thank you.
