FS: Big red (993TT) brake kit for 964
I have a big red front brake conversion kit for 964. Kit includes two refinished genuine Porsche 993TT front calipers, new genuine Porsche front rotors, new genuine Porsche OEM brake pads and Racers Edge MC-6000 brake caliper adapters.
The calipers were refinished by completely stripping them down, media blasting with walnut shell, painted with 1200 degree ceramic enamel and assembled with new Brembo seals and new Stoptech silicone dust boots. I got tired of the factory Brembo paint yellowing with track use and the brembo EPDM dust boots cracking. The ceramic paint will not yellow and the silicone dust boots will not crack.
$2300
$2300
Incredibly simple. Undo flexible brake line to stock caliper. Undo the 2 bolts that attach your stock caliper to the wheel carrier. Remove caliper. Slide your stock rotors off the wheel studs. Slide larger ventilated rotor on studs. Bolt adapters to wheel carrier and tighten two bolts. Bolt 993TT caliper to the adapter and tighten two bolts. Slide new pads into calipers. Bleed brakes. Job done!
Basic Sponsor
Very clean overhaul you did!
Glws
Glws
