Lowering help
#31
So I guess the question is. Will those springs from d911 fit and work? I'm pretty sure they will.
#32
My h&r lowering springs should be here on the 28th apparantly Anyone got any advice on doing the job?
#33
I used this DIY pdf plus a few other threads that are linked to yours on setting ride height. Good luck and have fun
https://www.google.com/url?q=http://...sU2ue7E1DpOGAb
#34
That is awesome, thankyou for that I'm unsure if I'll try and attack it when they arrive or wait until dad comes to visit at the end of January. Really excited!
#35
I have realised there is absolutely no way I can wait for another month to install the springs, I'm far to excited! They should be here by the end of the week, so I'm thinking I'll go out to the shed every day and spray some wd40 on all of the nuts that I'll be taking off. Does this sound like a good thing to do?
#36
Technical Guru
#38
Thanks guys.
#39
My springs have finally arrived!
Das fahrwerk!
Das fahrwerk!
#40
Stupid question here, the torque specs for the 3 13mm strut bolts is:
27 ft/lbs for post 91
15 ft/lbs for pre 91
if my car is a 91 model, which one do I do?
#41
Is the strut the early version or the lowered revised version? Post a picture will help.
#42
Revised edition. 91+
#45
Thanks for that, it was tight getting those torqued up, I ended up using the crows foot I got for my engine sump plug in there!
