weekndr build
#121
It's always fun reading people's reactions to this simple upgrade.I was amazed too and couldn't believe how locked down the car felt.
The 964 platform responds so well to simple mods like upgraded motor mounts, steering rack brace and bushings, tie rods, Wong chip and muffler bypasses. Totally changes everything.
Like motor mounts, I think the function first trans insert (orange - soft) bumps up the connection to the car, but isn't harsh to people that like RS or Wevo MM. People are missing out on this great mod.
I'll need to do these soon too.
And I have not heard of Function First, so I will give them a look!
I’m also running the Wevo’s but with the black pillows and I will say they actually do a great job of reducing noise and vibration. Yes it’s more than the stock but it’s definitely not annoying or extreme. The difference in handling and tightness is immediate, far more go kart like.
Did you install your brakes yet?
Was going to start with Blue and try Black if I didn't like it.
But I love it.
My car is already a very "harsh" street car - and with no radio, and emphasis on lightness.
The NVH from the engine mounts is welcomed.
New brake rotors/pads/fluid go on in 2 weeks.
Going to try a new shop in Denver, and also have them undo the crazy wiring I discovered when deleting the dash.
I was watching your IG story and that engine Tin = devil hahaha. I didnt' know Rothsport made a reinforced carrier as I though only Rennline made it.
For my own edification what were the oem mounts like? My car came with the Wevo blue along with primary and secondary muffler deletes so i'm curious. (I could've messaged on IG but since i'm here LOL)
After I pulled them out, I could easily manipulate the mounting rod with my hands.
Granted they were blown out and not functioning as intended.
They just numbed everything out in the cabin.
Connection between shifter, gas pedal and engine wasn't apparent.
Now I can feel my inputs, and their immediate output.
964Luftballoon (03-05-2020)
#122
I completely neglected the transmission mounts.
Well the oem mounts... just numbed everything out in the cabin. Connection between shifter, gas pedal and engine wasn't apparent. Now I can feel my inputs, and their immediate output.
weekndr.porsche (03-05-2020)
#123
Here is what the interior looks like after the lower dash delete.
Also Rennline passenger block off plate.
Ignore the wiring - that will all be cut out/tidied up in 2 weeks.
Here's the before:
And then the after:
Note the exposed channel in the center console if you remove the "bridge" piece I noted.
This would be fixed with some RS carpets...
Here's the before:
And then the after:
The following 2 users liked this post by weekndr.porsche:
911Jetta (03-06-2020),
Marine Blue (03-06-2020)
weekndr.porsche (03-06-2020)
#125
Winter Projects mostly complete.
Just got the car back after replacing the brake pads, rotors and fluid.
The shop also fixed the wiring issue with the keyless entry system - removing it, and cleaned up the mess greatly.
The only other thing I need to be ready for a long drive is new tires.
My first planned Rally was in late April, but has been postponed.
So I will have to plan something else.
#126
After deleting the lower dash, I didn't expect the center tunnel and passenger footwell to look so exposed and unfinished.
So I purchased a set of cashmere pieces from an '89 - since they didn't include the larger dash, and covered up more of the components.
Here is the result.
Looks finished and proper now.
Here is the result.
#127
Interior is done done.
Finished off with the center console switch plate fix by David Etter.
Now my broken switch plate, actually sits flush with the console trim.
New tires next, then lots of driving this Summer.
964Luftballoon (04-01-2020),
kos11-12 (11-20-2020)
weekndr.porsche (04-01-2020)
#129
I'm about to blow out my stock parts pile that is growing in the garage.
Before I make an official for sale thread, reach out if you want any of the following:
D90 Wheels
OEM 4 Way Cashmere Leather Seats
OEM Steering Wheel with Airbag
OEM Primary Muffler
OEM Cat with O2 Sensor
OEM Fog Lights
OEM H5 Headlights with GPW Trim
1990 Black Lower Dash Complete
OEM Passenger Airbag w/ dash cover
OEM Cashmere Door Cards
OEM Front Seat Belts
OEM Rear Seat Belts
OEM Rear Seat Backs
OEM Swaybars
OEM Rear Tail lights
OEM Center Console and Right Footwell Carpets
OEM Cashmere Shift ****
OEM Cashmere E Brake Lever
OEM Rear Spring Plates
OEM Struts and Springs
OEM Front Bumperettes
OEM Front Reflector Delete Plates
Leftover Brake Components
Wheel Spacers, Rennline and Elephant Racing
OEM End links
OEM Heater Blower
OEM Airbox
D90 Wheels
OEM Primary Muffler
OEM Fog Lights
OEM Rear Seat Belts
OEM Rear Seat Backs
OEM Swaybars
OEM End links
OEM Heater Blower
OEM Airbox
#131
#132
For Sale thread for all of my parts is now up:
https://rennlist.com/forums/964-foru...l#post16561997
#133
Long time, no update.
Roads in Colorado are finally drying out, the sand is getting pushed to the edge, and mountain passes are opening.
Great time to enjoy the car.
Here is a recent photo from a time spent with local photographer @reed_greiter
The following 4 users liked this post by weekndr.porsche:
#134
weekndr.porsche (05-19-2020)
