Mounting hardware kits are being assembled. The top ones are for the left-right edges. It should make the whole install very easy, regardless all will be explained and demonstrated in the DIY video. I will be picking up the frames from laser cutter on Friday, boxing it up on the weekend and shipping throughout next week. While the kits are on their way I will make the DIY video.
Hi Andrew, I'm sure you've got it covered but was wondering what packaging you intend to use for overseas shipments? UK carriers have a habit of folding parcels in half and kicking them all the way from the depot to your door.
It’s not just a British thing, you should have seen the last couple of packages my family sent me. They looked like they were dropped from a second floor window, and then used as a ball for a soccer match between the postal carriers.
I will be using essentially what "looks" like a fedex tube 38" x 6" x 6" x 6"(96.52 cm x 15.24 cm x 15.24 cm x 15.24 cm). I planned extra kits to replace lost, damaged or stolen if that happens. All kits will be insured. Last round only one kit got damaged.
Just got most of the order in. 15 frames in total, the rest should be ready early next week. Should have the first 15 ready for shipping warlu next week too. Unfortunately Canada Post went on strike, so delivery times will be most likely extended.
I would be all over it if only you could make a swap of the rear reflector with it. Yeah mine is in good condition but this rehab project looks so good I would like to get one...
Think ahead (aka Be Prepared), eventually you will wish you had this as the heat, sun and vibration makes your rear reflector less than desirable in appearance
