Footwell Heat / Hot Sill Again
#46
Wouldn't surprise me if the previous owner did this to stop water
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Thanks for all the info MaKSiNG
#47
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Thanks back at you 964George
Now let's say this is a source of water ingress on our cars though, why would our cars suffer from this? There must be a another reason.
And you are sure your plastic connection pieces are seated correctly? They "apparently" need to snap into place to form a tight seal.
#48
If water is coming in through the HVAC ducts that is a symptom not a cause (there shouldn't be any water in there to begin with). If your frunk seal is bad (usually torn at one or both top corners) that will dump water into the footwell(s) without leaving much other evidence; maybe start there.
