964 Forum 1989-1994
Oil in Cat... now what?
Old Aug 31, 2018 | 10:29 AM
No_snivelling's Avatar
No_snivelling
Default Oil in Cat... now what?
When I dropped the cat on my '92 C4, i was able to drain about a cup of oil out of it. Yikes! I can also see a pool of oil in the pipe leading back towards the engine. I can easily suck out the pool of oil, but is there anything else I should be doing? I have set the cat in a vertical orientation so any excess oil will drain out, but should it be washed or blown out with gentle application of compressed air maybe? Interestingly the exit side of the cat looked dry and perfectly normal so maybe there is some hope that the cat is not toast. There are lots of scary YouTube videos on how to clean a cat. I would rather trust the advice I get on Rennlist as opposed to the guy on YouTube who uses lacquer thinner, or drills a hole in the cat and then injects varsol WHILE THE ENGINE IS RUNNING.
Old Aug 31, 2018 | 10:37 AM
eZg's Avatar
eZg
I am NOT recommending it....but bringing it up in hope that it might spark a more knowledgeable mechanic.........I've heard of using Diesel gas to wash out oil in coolers and such.
Good luck....
Old Aug 31, 2018 | 10:41 AM
No_snivelling
I was thinking about using gasoline, since a cat should be designed to handle some raw fuel that would get pumped though when an engine refuses to start.
Any thoughts?
Old Aug 31, 2018 | 10:52 AM
HDA's Avatar
HDA
What worries me is that you have a cup of oil in the cat.
Shouldn't you be more concerned of that than how to clean the cat?
Old Aug 31, 2018 | 11:17 AM
18T_BT's Avatar
18T_BT
Yeah, excess oil in the CAT isn't a good thing. Usually, a sign of bad blow by of piston rings or valves getting gunked up and allowing oil to sneak by.
Cleaning it is easy. Let it sit overnight upside down, then spray in there with brake cleaner or gas. Once you put it back on, whatever is left should burn out.
Old Aug 31, 2018 | 12:11 PM
No_snivelling
I am very concerned about how the oil got into the cat, but have a working theory on how this happened. The car was stored for 15 years. So the most likely explanation is that the oil in the reservoir tank drained back into the engine and over a long period of time some of the oil leaked past the rings and this oil got pushed out into the exhaust system when I started the engine. This is my first Porsche and had I known about this possibility, I would have taken steps to remove the oil before I started it but nothing I can do about that other than to accept the blame, chalk it up to experience, and move on. The car has only 25,000 miles on it so rings and valve guides should all be in good shape. I hope I have not damaged the engine. A new cat is bad enough, but if I have to rebuild an engine with this low mileage, I might shed a few tears and a lot of dollars.
Old Aug 31, 2018 | 04:12 PM
No_snivelling
I have been studying exhaust flow diagrams and am now troubled by the low spot created by the crossover tube and the possibility that there is another pool of oil sitting there. If I drop the whole header/heat exchanger system in order to flush out any oil, I am worried about snapping off the manifold studs at the connection to the cylinder heads. Will I damage the engine if I run it with the cat removed? The hope would be that it blows all residual oil out thereby eliminating the need to do any further disassembly.
I have shamelessly copied the following picture from a posting by Bill Verburg in this thread http://forums.pelicanparts.com/porsc...elp-964-a.html
Hope you don't mind Bill. Your posts really helped me understand the 964 exhaust system. Item 4 is the crossover with the low spot I am concerned about.
Old Aug 31, 2018 | 04:24 PM
Goughary's Avatar
Goughary
If you start it up- it'll just blow the oil out.
I'm surprised that much oil seeped out in the first place. But having sat for 15 years, it makes sense .
Clean the cat, which is easy enough. And get out and drive the car. When the motor is nice and hot, run it hard and any residual will burn off.
Let it sit for a couple days and start it. If you have a lot of white smoke, you know you are getting a reasonable amount of seepage past the rings into the upper cylinders. Take it from there.
Old Sep 1, 2018 | 10:29 AM
No_snivelling
Thanks! I will give that a try after I finish setting valves and take care of a few other maintenance items.
Old Sep 2, 2018 | 07:16 PM
cjoenck's Avatar
cjoenck
The only “functional” part of a converter is a ceramic open-ended honeycomb with a platinum-palladium coating. It functions by converting any bonded nitrogen and oxygen molecules that come into contact with the hot platinum-palladium into nitrogen and oxygen. The freed oxygen is then caught by the passing CO to create CO2 and the passing unburned HC molecules to “combust” into CO2 and H2O (ideally). The only two modes of failure are coating of the ceramic with deposits from excessive oil consumption, which prevents the molecules from touching the platinum-palladium and stops the converter from performing or physical destruction of the honey comb ceramic - not the case here. The point is that a typically catalyst works on contact so excessive oil may not just burn off but could leave residue that could impact the cat's effectiveness.
Old Sep 3, 2018 | 04:11 PM
No_snivelling
You know, I love my car despite taking delivery of it in March and never having driven it. I have been fixing it since March and one would think by now I would be regretting the purchase but that is not the case.
To be fair, I have not been working on only when time allows, but I have invested a lot of hours and a small chunk of change. Thankfully there has been tangible progress. Some call it bonding with the car and I guess that is true to some extent , but what I find really rewarding is the knowledge gained. Every step of the way, there is a new challenge that involves research and learning. Rennlist, Pelican and Google have been my best friends since March. The oily cat is just the latest example. Cjoenck has taken the time to explain some of the intricacies of how a cat functions and that inspired me to dig into it a bit deeper. Wikipedia has a great writeup at https://en.wikipedia.org/wiki/Catalytic_converter . This article confirms much of what Cjoenck says but also goes further.
What I learned from Wiki leads to even more questions and some shocking info about ZDDP additives in engine oil. If you go to Wiki scroll down to the "Damage" section. In essence, Zinc is a low-level catalyst contaminant that can harm your cat. So if you are using ZDDP oil, you could be harming your cat. But there is some good news also. The article claims that " Depending on the contaminant, catalyst poisoning can sometimes be reversed by running the engine under a very heavy load for an extended period of time. The increased exhaust temperature can sometimes vaporize or sublimate the contaminant, removing it from the catalytic surface. "
I am therefore hopeful that after washing my cat, an Italian tuneup can finish the job.
Old Sep 3, 2018 | 04:23 PM
Goughary's Avatar
Goughary
Yes wash the cat. Blow out the oil in the tea of the exhaust (manifold and cross over pipe. Reinstall and Italian time up.
Do not, under any circumstances- use oil devoid of zddp to save a cat. Your engine will last a very short while before needing a rebuild .
Zddp was in the oil for a reason. And our cars depend on it. Soooooo Brad Penn it is...
Old Sep 3, 2018 | 04:24 PM
Richard H's Avatar
Richard H
I would suggest searching the 964 forum for ZDDP. There has been lots of debate about the reduction of zinc in oils and the damage it can cause to cams etc.
Old Sep 3, 2018 | 04:54 PM
cjoenck's Avatar
cjoenck
Our engines are based on design considerations during the early days of emission control in Europe and some of the oil requirements for these engines like ZDDP were not 100% aligned with catalyst requirements as emissions control was considered a required evil. Remember that the car manufacturers had to be dragged into emissions compliance kicking and screaming. I am dating myself here but catalysts where made responsible for loss of power, less fuel efficiency etc. in the early days.
As engine development and with that oil formulation evolved, ZDDP became less important and "modern" oil has far less of it. Today catalysts are much more an integral part of an engine than in the 90s and cat requirements and engine design are more aligned.
Bottom line, classic engine and modern oil formulation do not necessarily make a good combo. I am really not trying to start yet another oil discussion- just a little history
Old Sep 3, 2018 | 04:58 PM
No_snivelling
Thanks guys! I was not implying that I would not use ZDDP oil but would need to do more research. Every question leads to another right? Based on what I have heard so far it sounds like I need ZDDP oil and have noted that Wiki says it is a LOW-LEVEL contaminant. But if I may, here is another question that came up in my research. Why is it that when using a cat bypass, the exhaust smell becomes so foul? Long before we had cats on our cars, I don't recall the exhaust being particularly bad smelling. Did a lead reaction eliminate the smell back when he still had leaded fuel, or is the smell coming from folks who are force to run ethanol?
