964 Cars without Engine Under tray Installed
Definitely will take you up on the offer. The car is getting AC work and while it's currently on a lift I've had some time to try and see what brackets or components were still attached. Didn't seem to have much left at all. There is a broken bolt or stud that the mechanic is going to remove for me later where I believe the center back bolt secures to on the undertray. I'll go back next week and take some detailed pics of my current setup so we can compare notes. Thanks for the offer. I'll PM you later to get your number.
You won't need that center rear bolt. It acts a. It as a guide for the rear shields, but it sticks down so far in all likelihood yu will hit it at some point and bend it again.
Are your heat shields for sale by chance? Problem with sourcing is it's adding up quick at today's prices and looking for which brackets are necessary to mount each one. PET catalog is a good start, but with all those items missing I'm trying to get decent pictures to see what I needed. I wish the PO would have left the heat shields in place and just removed the undertray.
Gotcha, so don't worry about extracting what's left. Thanks for the input. Will hit you back up next week with the pics.
I can find them, but the bargain hunting is what's key. At least I got the undertray for $175.00 a few weeks ago. That was a bargain compared to brand new from Porsche or Pelican.
50-100 each is what you will find the others for. You may pick up pairs or a set at a cheaper per unit price. There are four pieces to buy.
And if you get stuck, you just call a dismantler and pay up a bit. No biggie.
Post some pics when you are next under the car. So we can see what's there
Autobahn in San Diego (El Cajon) gets tons of parts from the disassembled Singer cars. I wouldn’t be surprised if they have all the parts you need. Ask for Mike and see if he’ll cut you a deal for all the parts. Shipping is usually the killer so definitely buy them all at once.
Good luck.
I’m a bit miffed that your heat shields are missing, seems like an essential part of the car. Were you aware of this when you purchased the car?
Good luck.
I've dealt with LA Dismantlers on occasion but never tried Autobahn. I'll see what they have to offer. Thanks for the info.
Plenty of good advise about heat shields being necessary and why owners dump the lower tray but it's also worth mentioning to check the oil cooler fan is working on both low and high speed. I would guess 75% or more will not work on low speed for one reason or another. If your car runs with oil temp at 9 o'clock you can be fairly sure the low speed fan ain't working.
You are pretty much spot on. The ones that you don't need are:
And then you seem to be missing the two exhaust shields in front of the car as well. Hard to tell from the pics.
Anyway- those are the parts you need to source.
I'll call you this morning to discuss.
I drive with the tray on... daily until 6 months ago, now just very regularly. Can't say I have a overheating problem and it goes to 120 here, with high humidity (well over 85%, but never at 120 that would be at 105).
So take that for what it is, but if cars have cooling problems I suspect some systems are not working 100%. Extended traffic jams may prove to be an issue, but not so much here. Hot weather and LA traffic, that I wouldn't try.
