Upgrade advice
Location: WhippetWorld, .........is it really only this many
1 Post
Erick,
Please excuse my ignorance, but is the RSA MO30 suspension different from the standard C2 suspension? It`s just that I found the difference between the stock C2 setup and my H+R coilovers obvious as far as the track was concerned. Having said that, I would agree ,that as far as a track set-up is concerned, the H+R`s are too soft. However I`m not convinced that it would be possible to go significantly stiffer ( and replacing the suspension again ) without making the car unsuitable for the road.
For $ 5k, I would go with the 310 hp Lenz system. Do a search on Lenz. I posted the link to their website a while back. My shop got to try out a Lenz system and got the dyno results for it. I was told that their claims are accurate. This system will give you about the same improvements I have gained through a lot costlier route.
Originally posted by tonytaylor
... but is the RSA MO30 suspension different from the standard C2 suspension? ....
