targa wind noise
thanks
I have heard legends of mythical Targas that are relatively quiet and water tight, but never seen or been in one. They are best with the top off 😎
Good luck!
That was after he had the top rebuilt by a local guy which didn’t really understand how to rebuild them. Took me forever to remove the tape residue!
I was planning on having Dan rebuild mine too but it sounds like I should save my money as it doesn’t make a difference.
There is something that has worked for me for years - foam rolls you can buy in any hardware store or Lowes / Home Depot that is used to fill cracks in concrete. It comes in different thickness and is flexible. I squeeze it into the groove of the top windshield seal. It has significantly cut down on wind noise and no leaks - unless I am driving through a major downpour.
The car generates a low pressure area above the roof at speed. Consequently the flexible roof wants to rise into the low pressure and in doing so slightly reduces pressure on the folding frame which then flexes a little from both front and back towards the middle. This allows the roof frame to flex a little more, and in so doing opens up the seals slightly, so creating increasing wind noise as speed increases.
I know of someone in the UK who made up a carbon rod of perfect length for his car to insert between the front and back of the removable roof frame, thereby reducing any flex and in theory helping keep the seals tight. He says its works well and also gives some reassurance that at really high speeds the roof is not going to get sucked out and disappear down the road.
My 964 C2 has been away for work for several months now and is due back in a couple of weeks. I've asked the guys to make up a carbon rod with custom brackets to fit the back and front of the roof frame together with an integral locking/tensioner to provide a tight fit that can be easily removed to get the roof off. New roof seals fitted too.
I'll let you have an update in a couple of weeks together with some photos. Fingers crossed.
Having completed a few hundred miles now with this roof brace in place, I'm sure that it's helped reduce wind noise at speed. It can be tightened up (11mm spanner/wrench) once the roof has been normally located and locked in place using the OEM handles. The main benefit is at higher speeds when the roof wants to lift and flex in a little on itself. It provides a certain amount of peace of mind at much higher speeds too as it's just about impossible for the roof to lift off completely with this in place. I've seen that Targa roofs have been stolen off parked cars, so perhaps it makes theft a little less likely too. It's an easy to do improvement on all Targas.
He rebuilds them on a JIG and they are usually spot on.
You wind noise may be coming from the windows which are not adjusted right .
Elliot
