Scantool Problems
It could also be a problem on the OBD-bus in the car. Maybe one of the units connected to the bus is disturbing the signals.
As a side note, I most often see the idle adaptation process exit with a fault message, also in the original Porsche OBD tools. However, the idle is indeed adjusted, despite the warning.
Cheers,
Tore
Anyone else remember this?
There's also a note in the "Scantool Release Notes.txt" file that says:
Tore uses a FT232R usb serial chip in his device which is plug and play, and has a reliable windows driver. I can't believe it's a windows issue.
The one thing I would suggest is to look into the female plug of the diagnostic port and be sure the receptacles aren't spread to wide and they aren't clamping down on the male pins of the 19 pin plug. If the individual plug is out-of-round or spread to much, you can gently insert a pin or flat blade screwdriver between the plastic housing and the wall of the female receptacle and close it up a little and make it round. For what it's worth, see below for the individual female receptacle and the male pin of the diagnostic port. I had this problem at one time as I was plugging in/out scantools, hammers, oscilloscope probes in the port.
You say that the scantool connects and shows the serial numbers of the various modules. Is that every time you connect?.... and then it disconnects when you try to enter into a particular module? I'm looking at your post #5.
What I can do is ship my Hammer to you, you do what you need to do, and if the hammer works, then all is good. You can send it back with your Tore USB adapter, and I can look at it. Not that I suspect the hardware, but I do have a Win 7 machine, not a Thinkpad though. I'd like to figure out the cause of this disconnect. If it's an issue with your car's diagnostic bus (intermittent ground, etc.) I would think the Hammer would have the same problem.
PM me if your interested.
Kevin
I was literally in Encinitas 4 hours ago for a lunch meeting!!!!
