Keeping a 964 on the road.
#31
After a bit of a break, due mainly to the extended season of rain we seem to be having, I was finally able to get a few hours work in on the Black Pig.
Started tidying up the wiring again. Pulled all the interior lights and most of the seat wiring. Not sure if I will chop it all out or safely wrap it up (just in case) so now i have deleted; Headlight washers with motor, large washer reservoir, intensive washer has been used as only washer, front fogs, sunroof, rear wiper, interior lights, side indicators ( will be relocated). Considering deleting, rear screen demist, rear fogs, all seat electrics ( need new seats first) rear speakers, heated washer jets, amp and anything else I find along the way which is useless. managed to get a good coat of underseal on the inner wings and fit some grommets inside the car using a free flowing silicone to keep the moisture/water out. Have also just got rid of the spoiler motor, control box, wiring and will replace the spoiler with some mesh. I was unsure if the spoiler control box also has some sort of link to the speedo, hopefully it will still work!
#32
Silicone under and around the grommet, should keep water out. Will probably underseal it too.
Cleaned the inner wing and then applied a nice coat of underseal. Will be removing all the front suspension some time and will apply more then.
#33
Great job on your 964, Do you see a part number on that plug just above the large plug withe harness coming through, I you find the part number for that plug can you PM me, Thank you
#34
Technical Guru
The large rubber plugs (7) are part no. 99970319540, and the smaller plugs (2) are part no. 99970319640. I thought I found the part number for the two little cone shaped plugs in the floor, but the ones I found are too small. If anyone has the part no. for the cone shaped plugs (2), please share.
All the body plugs are Audi/VW parts (ex. 999-703-195-40 was originally 803-803-583). So if you know the dimensions of the hole its not too bad to find the cover/sealing plug in those PET catalogs. Can you post a photo of the cone shaped plugs and the general location (i'm away from cars in NE until summer).
#36
Thanks Jason,
Here’s a photo of the cone shaped plugs next to the other round plugs. It’s been a while since I removed them, and the car is gutted, but I think they were set in the floor in the rear footwells. I will have a look tonight and measure the hole.
Jim
Cone shaped plugs at bottom
Jim
#37
Thanks Jason,
Jim
Jim
#38
Jim
Hole is located here in the rear floor board just under the cable outlet.
Here’s a closeup
#39
So you have a black pig and I have a white pig. LOL. Keep up the great work on your car. These cars are worth the effort.
#40
I’m guessing they’re cone shaped so that any accumulating moisture down below drains down and away from the floor boards. I’m on a mission to restore the car with all OEM equipment (except the suspension and mods of course ).
#41
I would love to pull the wings like yourself but I've not got the time and one of the wings has the spot weld, so I'm getting a body shop to do this for me, along with some other work, so made sense...
I will then concentrate on stripping the interior once it's back
Keep up the good work and keep those posts coming.
#44
You've got a week of decent weather before we're back to rain
#45
Managed a bit of time on the car. Decided to sort the suspension. One thing lead to another and now I have the whole steering assembly off except for the rack. Refurb bushes and clean up and make good all the other bits. I am still awaiting the Fenn Lane sunroof panel so I needed something to keep me busy. Hopefully get some pictures posted.
