Wiring for reverse lights
Is it safe to assume you can cut the wiring to the rear reflector in a 964 for the reverse lights and connect those same wires directly to something like this:
http://adrenalinelights.org/?product=3-flood-led-cube
I am moving to a grille instead of the reflector (for air flow) and looking for a creative way to keep reverse lights.
Best,
Kris
Best,
Kris
IHI KING!
Wiring wise, yes you can cut and splice as you want. I would double check the wattage of your new lights compared to the originals. There is not a relay in the backup light circuit, so you don't want to over heat your backup light switch.
I would just get some crimp on lugs to fit in the plug instead of cutting the wires. and wattage isnt a problem I had some 55 watt halogen back up bulbs in there for a while , no problems with wiring but they melted the plastic on the reflector
