Help! 964 Sunroof part numbers??
Hello. I would be very appreciative if someone out there can tell me the part numbers for the washers and what appears to be a nut of some kind for the rear sunroof adjustment included in the yellow circle. I've stared at the parts illustration and searched a number of parts on Pelican but cannot seem to find the nut that secures the hexagon bolt (or the two washers). The nut has teeth on the end that mates with what I believe is the guide. Since I purchased my 964 a few months ago the passenger rear has been low and I've now just got around to it (other priorities of a driver...). Thanks in advance!
Unfortunately I cannot locate it on the parts catalog. I've searched most of the part numbers that even slightly resemble the part I need. Here's another picture of it from the backside. It's the half moon shaped nut.
Not sure if this will be helpful or not, but when my car was repainted I had to source a few new sunroof parts. From what has been told to me, the earlier design was superseded and parts are nla. Not sure what year that happened or if it's even a legit thing. My car is a 90
Good luck with sunroof work, i guess its complicated, i just ordered seals for mine and took to a shop to install, i thought it was a simple quick job, ended up costing me $275 just to get the seals installed
It is relatively easy to replace the seals just takes a couple of hours to do properly. The design has been around forever. You might source the parts at a dismantler. Otherwise I believe John is correct and is part of the cable. Getting that adjustment right is not as easy as it seems and the roof is removable without disassembling. If you don't get it correct it can scrape the lid when opening/
