More Water Ingress
Hi
Where did you get the bonnet seal from? Also, is the replacement of the front trunk seal something someone could do without a lot of tools and technical know how or better done at a shop?
Rob
Rob
Buy a frunk seal from Porsche dealer,
https://www.sonnenporscheoemparts.co...bC1oNi1nYXM%3D
pull the old one out, clean out the old glue and glue the new one in using black weatherstrip adhesive. Cleaning the old glue takes time but can be done. 3M makes an adhesive remover that helps, so does a plastic scraper. I also filled around and under the seal using 3M bedding compound to keep water out from under the seal (in case the weatherstrip adhesive didn’t adhere completely. Bedding compound is not OEM but it’s important to keep water out from under the weatherstrip otherwise rust will occur.
Cut a short piece of rubber vacuum hose on an angle and push it over the weatherstrip adhesive tube tip, this makes it really easy to apply and spread the adhesive without making a big mess.
Good luck.
Good luck.
https://www.amazon.com/3M-08008-Black-Weatherstrip-Adhesive/dp/B00063X38M/ref=sr_1_1?ie=UTF8&qid=1519875589&sr=8-1&keywords=3m+weather+strip+adhesive&dpID=41hizfT36%252BL&preST=_SY300_QL70_&dpSrc=srch
If you are in the UK, you can get the seal from type911. As 540964 says, its a question of cleaning up the area and then ensuring it is sealed well to stop any water ingress.
I washed the 964 last night and then noticed some water ingress inside the frunk and somehow inside the side vents.
My frunk seal is split in the left top corner and I suppose that is what could lead to water entering the frunk area and pool (see area with surface rust), however I am not seeing any water drops anywhere that would support this.. Any other suggestions?
The most puzzling part is that I have the dash part to work on some electrical and I noticed water in the left side vent after washing the 964. I have no idea where this could be coming from, any ideas?
My WAG is that the evaporator box drains are clogged, though it doesn't make sense as floor vents would get wet first due to the HVAC suitcase's outlets. Perhaps if you pop the blower covers you might see some evidence of water pooling. Aside from that I don't have anything.
Check the upper bellows, fresh air into suitcase. If not fitted properly water will leak into the frunk area and likely run down through the penetrations for ducts into the passenger compartment. Number 23 on this drawing.
Had my bonnet seal replaced recently but it appears that I still have a leak...
its coming in via the heater elbow as described by 5hrine!
I felt it and the sponge seal is soaking wet!
Drivers footwell...
Between the drivers seat and sill...
Rear footwell...
Could this be the cause?
Kink in wing seal at top corner of bonnet...
More investigation needed!
Dread to think what state the pedal box is in!
Might be doing the carpet strip out sooner than I thought
Drivers footwell...
Rear footwell...
If I was you I would remove the wings. I took both mine off and revealed some rust just up where the seal is kinked on yours. It's a bit of a pain but worth it in the long run. I used phosphoric acid to neutralise the rust area after stripping to bare metal.
I fought water ingress for a long time. There are likely a number of little things. The kink in the wing seal not helping. I had to reinstall the bonnet seal a half-dozen times to get it just perfect and water tight. Any imperfection in adhesion will result in a leak. Fix the split with a little 3M adhesive.
For the leak in that little cubby, these are the places where i found watering coming into the frunk on my car: windshield wiper seals, washer fluid seals, fresh air inlet seals, and a marginally installed bonnet seal. After those were cleaned up, i was water free up top. There were other sources for the lower portion of the frunk. Search my prior posts and frunk water posts if you haven't already.
I found the inner wing panel had a seam that was letting water in. About half way down . It was running between inner and outer wing finding the non seam sealed join running inside the wing and then along towards the rear of the trunk on the raised section with the brake fluid reservoir attached to in. Then into the back behind the petrol tank. Only found it by accident as it looked sealed. But after the outer wing came off I could see a little gap. Seam seal should cure it hopefully.
What part are you referring to when you say "washer fluid seals?"
And if you have it handy, a part number for the windshield wiper seals? There are a number of parts listed on page 534 of the PET but they are mostly referred to as "bush(es/ing)" and I'm curious what exactly you replaced to solve the leak.
Thanks!
