Rear windshield question
I know someone out there can answer this for me many thanks ahead of time.
I know the front window is glued in but I can’t find out if the rear is also. I lean towards it NOT being glued in. The rear when I removed it had what appeared to be some sort of adhesive on it but definitely not the black Pima stuff like the front
Per the service manual (section 5, 64-12 through 64-16) it does use adhesive to hold in place. Given it says to install within 4 hours of applying adhesive, I’d wager it’s also urethane.
Thanks Des All I have to view this stuff is an IPhone. I have Adrian’s book so I guess I will follow the same gluing method for the rear as the front. Again many many thanks😎
Send me a DM with your email and I’ll send you the file for that.
