964 Forum 1989-1994
Clear power steering reservoir sources
Old 02-05-2018, 02:04 PM
18T_BT
18T_BT's Avatar
No affiliation: https://www.ebay.com/itm/Porsche-911...-/222072073835
Old 02-12-2018, 06:01 AM
MA7008O
MA7008O's Avatar
Just checked the O-ring and it was gone. Changed.
On more question with regards the vent hole. I blow through it and could listen to air going pass both ways: in and out. Is that out or is the ventilation valve also gone?
Thanks,
Old 02-12-2018, 10:33 AM
tfitch03
tfitch03's Avatar
mine was leaking around the same location as yours. I changed the "L" shaped rubber hose going to the pump and that fixed the leak. I guess the old hose was damaged.
Old 02-12-2018, 11:07 AM
mystert
mystert's Avatar
Thanks,
That's the ventilation hole for the reservoir. Fluid heats up and expands, air goes out the hole, it cools back down, air come back in the hole.
Old 02-12-2018, 11:37 AM
MA7008O
MA7008O's Avatar
Yes, but, can fluid go through?
Old 02-12-2018, 05:16 PM
mystert
mystert's Avatar
If you overfill the reservoir then yes. Its designed to be there.
Old 02-13-2018, 04:43 AM
MA7008O
MA7008O's Avatar
No overfill, never.
Let's see how it goes with just the new O-ring.
Old 02-26-2018, 09:05 PM
URO Support
URO Support's Avatar
If anyone was wondering, URO P/S Reservoir Cap Seal 32 41 1 128 333 is technically for a multitude of BMW applications, has a 42mm ID with a 2mm cross section, and is made of EPDM rubber. It's not surprising that the seal could fit a variety of Porsche applications however, since many Porsche and BMW models share power steering reservoirs.
Quick Reply: Clear power steering reservoir sources
