Battery Drain Dilema
Its really odd. the engine lid switch is there on the left, but I still cannot see a front bonnet switch anywhere. There is another (alarm?) switch inside the front on the slam panel, but no light switch. I will take another look.
The luggage compartment light switch may be placed in the lock mechanism.
Measurements must be done with the car locked. Did you use the DIY guide here?
Cheers,
Tore
Cheers,
Tore
The bonnet switch is (should be) adjacent to the bonnet light which is located to illuminate the fuse/relay box. Also bear in mind that, on some cars if the bonnet is open and the light is on, the engine light will also be on even though the engine lid is closed.
Cheers,
Tore
Cheers,
Tore
luggage compartment light, but no switch
front (alarm?) switch . what is cut wire with the blue insulation /
Connector from main loom for trunk light has been cut and only one wire now runs from it to front trunk switch, via trunk light
Amp meter still reading around 270Ma with everything turned off, car locked. Removed CCU and it drops to 230Ma so CCU is drawing 40Ma at rest, fan was disconected on the back, so tested with/without fan connected and still only a 40Ma draw at rest, which seems a lot. With fan operational after IGN turned off reading is about 700Ma so CCU fan draws around 500Ma which also seems very high. Any ideas as its starting to be a bit confusing.
The 964 luggage compartment light switch is either placed in the lock mechanism or on the right fender, near the fuse box. (not on the lid) A common fault in the latter is that the switch becomes misplaced, and is not depressed when you close the compartment lid.
The CCU will be active with CCU fan running for up to 20 minutes after ignition off. My DIY test procedure describes how to avoid this feature when measuring current draw. The CCU normally draws 500-700mA when active, including the fan. If the CCU does not turn off within 20 minutes, its internal power switching circuit might be damaged. This is easily repaired.
Cheers,
Tore
Cheers,
Tore
Cheers,
Tore
Cheers,
Tore
Is this a factory fitted alarm ?
Could these chopped wires may be the cause?
Sorry Tore, on my 1990 C2, the front light switch is on the hood, between the two mounting bolts that attach the lid to the hinge.
I have a 1990 C2 also. There looks to be a hole between the two mounting bolts, (see pics above) must be for a switch, however the switch is not present, so assuming the button type switch at the front must be what is used now. This switch does not turn the trunk light off though. I thought it was for the alarm as its the same as the alarm switch in the engine compartment. I am wondering if this switch has anything to do with the remaining 200mA drain.
Cheers,
Tore
Cheers,
Tore
