964 Forum 1989-1994
My 964
Old 08-22-2018, 06:25 PM
  #346
Foxman
Foxman's Avatar
Originally Posted by Dingo
Thanks guys, I'll be using paint remover then. Nice project for the weekend! I'm thinking of using a black engine enamel spray, any thoughts on this? How would you flush the oil tank out? I was thinking of doing it just because I can.
SEM self etching primer, and Wurth black enamel.
If if you need to secure any hardware, try 3M panel bonding.
Old 08-22-2018, 06:48 PM
  #347
Dingo
Dingo's Avatar
Cheers Jim I'll see if I can find these products. Do you think heat from the tank will be an issue?
Old 08-22-2018, 09:04 PM
  #348
Foxman
Foxman's Avatar
Ang good durable enamel paint will work just fine. Wurth also make a high temperature paint, but it’s overkill and you can’t use any primer with that paint. If you’re stripping all the paint, you’ll want to use a self etching primer first.
Old 08-24-2018, 06:25 PM
  #349
Dingo
Dingo's Avatar
I'm beginning to get more and more paranoid about cleaning everything with the oil system. Does anyone know if I can clean the inside of the oil tank? I'm thinking why can't I just put some petrol in the tank, shake it around and drain it a few times?
Old 08-24-2018, 07:08 PM
  #350
fasterlaster
fasterlaster's Avatar
My fear of this is what if you dislodge a larger piece of something in the tank and it clogs an input, perhaps causing oil starvation later on. Not sure how valid my concern is, but I've always considered oil tanks/oil coolers to be something I'd prefer to pay to have properly cleaned inside/outside.
Old 08-24-2018, 07:15 PM
  #351
Dingo
Dingo's Avatar
Yes that makes perfect sense, I've had a bit of a look inside my tank and it looks like new, I'm just worried if I've accidentally gotten some dirt or dust inside.
Old 08-24-2018, 11:20 PM
  #352
Goughary
Goughary's Avatar
It's amazing how touching anything can become a can of worms...
This is one of those things where, you don't ask don't tell don't touch don't worry...or you send it out for cleaning.
Or...buy a scope and have fun looking in there...cuz fun.
This is a fun thread. Keep it up. You are doing really good stuff.
Old 08-24-2018, 11:35 PM
  #353
Dingo
Dingo's Avatar
You are not wrong about the can of worms! I've come to expect it now! I do enjoy it, but this job is making me quite anxious!
Man you are a legend, I never even thought of a scope.... I have a few cameras I use for work that plug into my phone!
I'm glad people are enjoying it! I have no idea what I'm doing but I will know this whole car inside out in about 10 years time haha
Old 08-28-2018, 03:20 AM
  #354
Dingo
Dingo's Avatar
Sandblasted
Quick coat of primer
Old 08-28-2018, 03:22 AM
  #355
Dingo
Dingo's Avatar
Got the oil tank back today. I'll put a few coats of paint on it tomorrow night then off for an ultrasonic bath on Friday.. hopefully I'll have the car running on the weekend if parts arrive!
Old 08-31-2018, 02:49 AM
  #356
Dingo
Dingo's Avatar
Replaced the thermostat mount today. Seems to be alot of pressure on it downwards.
Old 08-31-2018, 02:53 AM
  #357
Dingo
Dingo's Avatar
Cup holder!
Finally got all of the little black things that hold the center reflector on!
Old 08-31-2018, 04:22 PM
  #358
Richard H
Richard H's Avatar
Mine is the same
Old 08-31-2018, 06:41 PM
  #359
Dingo
Dingo's Avatar
Originally Posted by Richard H
Mine is the same
Wonder why?
Old 08-31-2018, 07:27 PM
  #360
Richard H
Richard H's Avatar
Wonder why?
I think it is because the thermostat is 'free floating' and therefore the position of the pipes and hoses govern the position of it. I did consider trying to adjust the position but thought it not worth it. If I remember my conclusion was that I would have had to shorten the rubber hoses to the oil tank by about 5mm to pull it up a bit and didn't really want to mees around with them. My mount had split and I have no idea how long it had been like that, probably quite a few years. In my opinion the thermostat is really held in position by all the pipes and hoses so the mount has very little effect. I did replace it anyway when I renewed all the hoses.
Quick Reply: My 964
