fan housing strap
fan housing strap
I ordered a new fan housing strap, Part number was 964 106 251 20. This is for a 1990 C2, My original is two piece and what a got was a one piece
Is this the correct replacement? Does it just go around the old mounting areas?
Technical Guru
If you have the old Windows based PC version of PET6 you can save yourself a ton of headaches by ignoring the online part websites. I don't trust any of them to have the correct numbers.
The Pet6 Windows program tries to install a zip server which is incompatible with windows zip service in Windows 7, 8 and 10. Maybe if you disable windows zip service it might work.
The biggest downside of the PDF pet is its not searchable as its all bit mapped images (may be getting confused with workshop manual...). Wondering if anyone could do a character recognition scan on it.
Technical Guru
If dlpalumbo's suggestions don't work (they should) then right click the setup executables that will not work, select the "Properties" menu and you'll find the option under the "Compatbility" tab.
If you use Acrobat (Reader), it is searchable (just use spaces instead of hyphens between number segments).
