Sharper steering?
Good info, still deciding on which ones to get. Seems like the FVD has billet cups and they have the ***** on opposite ends - not sure if that will make any difference.
Any one have experience with the FVD inner rods or are the Tarretts the way to go? https://www.fvd.net/us-en/9643470580...-monoball.html
Lots of good info in this thread, just looking to confirm the following:
- The Elephant "Bump Steer Tie Rod Kit" ($550) replaces both the inner and outer tie rods.
https://www.elephantracing.com/porsc...-rods-for-993/
- The Tarett "Front Tie Rod w/ Bump Steer" ($457) replaces only the outer tie rod and would be paired with Tarett (or ERP) "RSR Style" inner tie rods ($298.)
https://www.tarett.com/items/993-964...7#ITEM_7107120
If this is indeed the case, any reason I should go with the Tarett option for about $200 more?
The Elephant kit is a complete solution. The Tarrett Front Tie Rod with Bump Steer is for use with RS uprights, I don’t believe it’ll work with stock. The RSR inner tie rods pair with stock outers on stock uprights.
I chose the RSR inner with stock outer and have been happy with that combo on RS+10 ride height. I drove a car with the Elephant kit at RS ride height and it felt just as good. I think the Elephant kit is probably the best bet unless you have the RS uprights already installed.
